Thankyou @davidthewatson for your appreciation![]()
Me too ![]()
And probably a few more hundred (thousand) that give us the kernel, Calamares and Btrfs. ![]()
This list is incomplete. ![]()
We will discuss it soon in the team.
We always appreciate nice feedback, btw, and many thanks for your kind words
That Hyprland minimalism desktop is phenomenal. I really need to find out how to get hyprland working on Nvidia properly
Is Hyprland ready for work/play production? I thought it was still in the alpha/beta stage. ![]()
Basically, I wouldn't use it for production, Hyprland itself is certainly not bug-free yet, but it's fun to play around with it, so far I can't complain, runs smooth :-)!
All the https://iso.builds.garudalinux.org/* links in this thread return 502 for me, what's the latest build link?
Yeah , I am using this for some days now (I removed my older setup and installed the latest ISO in place of it ) , for me it is very snappy, my PC model is of around 2016 or 2017 so maybe because of this I didn't face any driver incompatibility , for newer once there can be
Try later, please, IT-Staff is in action.
Any news on any new hyprland iso builds?
What does not work after the installation?
The development process is completed so far.
On occasion I try to solve the calamares "problem" why the start of Garuda Welcome does not work.
Ahh nice - I wasn't sure - I'll download it now and test it on nvidia hardware.. I just wasn't sure
Report back on your experience with these ISOs and Nvidia please
Maybe you overlooked.
The Hyprland maintainers have pointed out that some Nvidia cards work fine, and some will not work, on a seemingly random basis.
There is no official support for Nvidia. Unfortunately, their drivers are so messy, and their products so random, that itās impossible for us to help if these instructions donāt work fully.
Every card seems to be random, and might work perfectly, or not work at all.
Nevertheless, itās recommended to at least try this tutorial.
Each Nvidia user will need to test their specific hardware setup individually to determine if they will be able to get Hyprland working or not. The outcome one person experiences will not indicate anything meaningful for another person, unless they have the exact same hardware configuration.
Go ahead and give it a try for yourself if you have an Nvidia card: Nvidia | Hyprland Wiki
I did see that, hoping for a few more successes before I go ahead and format that disk. Several hundred gb of re-downloads if I do.
You could install Hyprland in separate subvolumes to test it out, and leave your current installation intact. If it doesn't work out, just delete the Hyprland subvolumes.
No need to format your disk, re-download, or redo anything.
I do not see a mistake in
exists("/usr/bin/kvantummanager" is true and from terminal sudo -E calamares [-D8] works.
But ...
WTH ![]()
Too many solutions for me ![]()
garuda-welcome
QMetaObject::connectSlotsByName: No matching signal for on_buttonCryptpad_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_buttonBigbluebutton_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_buttonNextcloud_clicked()
"overlay"
kf.windowsystem: Could not find any platform plugin
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :1
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
/usr/bin/calamares_polkit: Zeile 6: 7361 Abgebrochen (Speicherabzug geschrieben) pkexec --disable-internal-agent "/usr/bin/calamares" "$@"
Hi,
Yes your ixi output is exactly what I found/had
I cannot run any of the "garuda" specific apps on the hyprland beta.
Snapper creates and rollbacks work - using the commandline functions. just the gui functionallity.
I didnt mention any of this before as I explained im a user and nowhere know what I am doing ![]()
So I cannot suggest a remedy.
I assumed others will get the same problems as I did and you have.
Tried reinstalling / installing all the options as pacman suggests , did not fix it.
that exhausts my capabilities.
Reporting it now as did not want to look a fool for something simple but as someone else has the exact thing it does look repeatable. Just seconding the above issue.
