Hyprland.conf changing on it's own?
I’m a long time arch/hyprland user and I decided to give the Garuda hyprland spin a try to see if might resolve some issues I’ve been having with gamescope. Things have been going smoothly except for the fact that each time I reboot the monitor section of my hyprland.conf gets reset from:
monitor= DP-2, 2560x1440, 0x0, 1
monitor= HDMI-A-1, 2560x1440@144, 2560x0, 1
monitor= DP-1, 2560x1440, 5120x0, 1
To:
monitor= HDMI-A-1, 2560x1440@143.91200, 2560x0, 1.00
The fact that this setting is being changed but my other changes are preserved adds further confusion to why this is happening. I’ve never experienced something like this on Arch. Does anyone know why this is happening/how to prevent it?
    root=UUID=929f184a-eeb9-4865-a7fc-c2a63ab33cfd rw rootflags=subvol=@
    quiet resume=UUID=d3328d0e-696b-4452-9367-b728161f8552 loglevel=3 ibt=off
    nvidia_drm.modeset=1
  Mobo: ASUSTeK model: TUF GAMING Z690-PLUS WIFI D4 v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1720
    date: 08/12/2022
  Device-1: wacom_battery_0 model: Wacom Intuos BT M serial: N/A charge: 100%
  Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
    microcode: 0x2E
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 864 high: 2096 min/max: 800/4900:5000:3800 scaling:
    driver: intel_pstate governor: performance cores: 1: 800 2: 801 3: 800
    4: 800 5: 801 6: 800 7: 798 8: 800 9: 800 10: 800 11: 797 12: 2096 13: 801
    14: 800 15: 800 16: 800 17: 801 18: 800 19: 800 20: 800 bogomips: 144383
  Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: DP-1,DP-2,HDMI-A-1 empty: DP-3
    bus-ID: 01:00.0 chip-ID: 10de:2684 class-ID: 0300
  Device-2: ASUSTek [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-3.1:5 chip-ID: 0b05:9d08 class-ID: 0e02
    compositor: Hyprland driver: X: loaded: nvidia unloaded: modesetting
    d-rect: 7680x1440 display-ID: 1
  Monitor-1: DP-1 pos: center model: 27E6QC serial: <filter> built: 2022
    res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2 scale: 1
    max: 2560x1440 min: 640x480
  Monitor-2: DP-2 pos: right model: 27E6QC serial: <filter> built: 2022
  Monitor-3: HDMI-A-1 pos: left model: AOC Q27G3G3R3 serial: <filter>
    built: 2022 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2 scale: 1
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
    memory: 23.43 GiB
  API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4090 driver: nvidia v: 535.113.01
    device-ID: 10de:2684 surfaces: xcb,xlib,wayland
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
  Device-2: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
  Device-3: ASUSTek [] driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.2:7 chip-ID: 0b05:9d09
    class-ID: 0102
  Device-4: Razer USA RZ19-0229 Gaming Microphone
    lanes: 1 mode: 1.1 bus-ID: 1-6.3:15 chip-ID: 1532:0511 class-ID: 0300
  Device-5: Corsair [] driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.4:17
    chip-ID: 1b1c:0a4d class-ID: 0300 serial: <filter>
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:18 chip-ID: 8087:0026
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 3.67 TiB used: 40.49 GiB (1.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 1TB
    model: WD10EARS-00Y5B1 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Cruzer Glide
    size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 914.24 GiB size: 914.24 GiB (100.00%)
    used: 40.49 GiB (4.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
    used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 914.24 GiB size: 914.24 GiB (100.00%)
  ID-4: /var/log raw-size: 914.24 GiB size: 914.24 GiB (100.00%)
  ID-5: /var/tmp raw-size: 914.24 GiB size: 914.24 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.43 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 24.0 C mobo: N/A
  Processes: 365 Uptime: 1h 12m wakeups: 1 Memory: total: 16 GiB
  available: 15.43 GiB used: 4.92 GiB (31.9%) Init: systemd v: 254
  pm: pacman pkgs: 1335 libs: 386 tools: paru Shell: fish v: 3.6.1
  running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-11-24
  Last full system update: 2023-11-24
  Is partially upgraded:   Yes
In your hyprland.conf search for mon.sh and comment out or delete that line. Save it and then make your changes.
Sure enough, that seemed to be the issue. Thanks!
Nope, no issue it’s a service :smiley:
# Set monitor values. For own values, please comment with #
exec-once = .local/bin/mon.sh
Maybe I must add an out? :eyes: :thinking:
If you want it to run once and then never again, you can move the exec-once line out of the main config to a drop-in config, then change the script so it will run, then delete the config and delete itself.
Here is an example of what this looks like:
This script launches a notification after the first boot, then deletes itself and deletes the drop-in config.
There are probably other ways to accomplish something like this, and maybe even more practical ones, but self-destructing like a Mission Impossible message is probably the coolest way. :sunglasses:
Yeah, or the Advanced User(s Only) just read. :sunglasses: :dark_sunglasses:
Automatically comment out after first run? :eyes:
:roll_eyes: I guess so–obviously it will not be as dramatic. :stuck_out_tongue_winking_eye:
Maybe add something like this to the end of the script:
sed -i "s|exec-once = .local/bin/mon.sh|#exec-once = .local/bin/mon.sh|" $HOME/.config/hypr/hyprland.conf
I have not tested, but seems like it should work. :crossed_fingers:
