Hi
I use the HyperX Cloud Flight S.
In Windows it showed 2 devices:
HyperX Cloud Flight S Chat
HyperX Cloud Flight S Game
my microphone sounds very bad. I suspect my system’s drivers use the Chat device since on windows it used to sound just as bad as now.
I found a thread on reddit that kind of sounds like my problem but I am not sure what exactly I am looking at…
https://www.reddit.com/r/HyperX/comments/fobp2s/cloud_flight_s_microphone_help_linux/
Any help is appreciated since I dont really know where to start.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4732ac51-588b-455d-be3c-f78050caac63 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
UEFI: American Megatrends v: M.20 date: 08/29/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3717 high: 3753 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3749 2: 3742
3: 3749 4: 3749 5: 3748 6: 3400 7: 3749 8: 3744 9: 3738 10: 3745 11: 3749
12: 3753 bogomips: 81589
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
bus-ID: 28:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab28
Device-2: Kingston HyperX Cloud Flight S
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 0951:16ea class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
Local Storage: total: 1.82 TiB used: 548.86 GiB (29.5%)
model: WD10EZEX-00MFCA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
used: 263.67 GiB (56.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.56 GiB used: 2.58 GiB (16.6%)
System Temperatures: cpu: 38.1 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 56.0 C
Memory: total: 16 GiB available: 15.56 GiB used: 6.66 GiB (42.8%)
Processes: 358 Power: uptime: 12h 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2014 libs: 553 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-09
Last full system update: 2024-03-20 ↻
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0951:16ea Kingston Technology HyperX Cloud Flight S
Bus 001 Device 004: ID 046d:c547 Logitech, Inc. USB Receiver
Bus 001 Device 005: ID 258a:002a SINO WEALTH Gaming KB
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
cat /proc/asound/cards
File: /proc/asound/cards
0 [HDMI ]: HDA-Intel - HDA ATI HDMI
HDA ATI HDMI at 0xfcb20000 irq 78
1 [S ]: USB-Audio - HyperX Cloud Flight S
Kingston HyperX Cloud Flight S at usb-0000:03:00.0-2, full speed
