On my main PC, I have need of a hypervisor to run a Windows 10 VM for work purposes. It helps separate work and home PC stuff.
I currently use VMWare Workstation on my Windows install, but I would love to some day move over to Linux (Likely Garuda, as I’ve been using it on my laptop and love it), I just need to know what’s the best way to do VMs on Garuda. Does VMware Workstation Player work well? Or should I look into KVM?
You should learn KVM (which you can install from the Garuda Assistant btw - makes the setup easier).
I think it has more features and better performance as it is a baremetal hypervisor.
It is great tool to use from my experience.
You can check out a few guides on the YT.
ChrisTitusTech has some nice videos…
It is easy to setup with virtmanager. you may need to configure the file
/etc/libvirt/qemu.conf
or add the user to the kvm group
You need to use tools like samba to share files between linux and windows, unless you install qemu drivers successfully on windows installation
Some More
Those drivers are fantastic and change size of VM resolution according to the size of windows (on X11) and support drag and drop to VM. Give minimum of 4 cores for usable VM, In My case I have 16 cores and gave 6 cores to win11 vm also you need to disable the windows update and disable animation in windows for better performance.
