Hey folks,
Been doing some research/reading on the forums and elsewhere and I’m hoping someone here would know more to help me understand how Garuda leverages hybrid graphics. Based on the Garuda Wiki it claims that “Garuda Linux by default only uses your integrated GPU to save power…” and that “The iGPU is much better suited for running low power common desktop applications.”
I have an Intel UHD Graphics 770 iGPU and NVIDIA GeForce RTX 3060 Ti dGPU. However, I can confirm that the intel igpu is not used at all (via intel_gpu_top
and btop
(don’t see any gpu activity). Furthermore, running glxinfo -B | grep "OpenGL vendor string"
results in OpenGL vendor string: NVIDIA Corporation
. Of course, pre-pending prime-run
to the same command has the same exact output.
I’m wondering if I use envycontrol
and switch to integrated
mode (currently envycontrol -q
shows hybrid
) and then utilize prime-run
for more graphic-intensive applications - would this correctly leverage my iGPU for more “low power common desktop applications” like the DE? I have a dual monitor setup, and they’re both plugged into 2 displayports on my NVIDIA card - would switching to integrated
mean I won’t get any output display?
Is there another way I should be thinking about this? If Garuda uses iGPU by default to save power, how can I confirm that it’s doing so, since all I’ve been able to see is that it’s using the NVIDIA card.
Secondarily, any benefits to using the Intel Xe driver?
Here’s my garuda-inxi
> garuda-inxi
Kernel: 6.17.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=8dcc0c9c-8fe9-4fc6-b189-a8db2cfa3823 rw rootflags=subvol=@
i915.enable_guc=3 i915.max_vfs=7 quiet
resume=UUID=a14a443b-9c6b-47d0-b49a-d9686d767b7c loglevel=3
sysrq_always_enabled=1 nvidia-drm.modeset=1
pci=disable_acs_redir=pci:12D8:2308
Mobo: ASUSTeK model: PRIME Z690-P WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3801 date: 05/14/2025
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
microcode: 0x3A
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 801 min/max: 800/5100:5200:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 801 3: 801 4: 801
5: 801 6: 801 7: 801 8: 801 9: 801 10: 801 11: 801 12: 801 13: 801 14: 801
15: 801 16: 801 17: 801 18: 801 19: 801 20: 801 21: 801 22: 801 23: 801
24: 801 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: ASUSTeK driver: nvidia v: 580.95.05 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-4,HDMI-A-4
empty: DP-3,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
Device-3: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12.4:11
chip-ID: 0bda:58ba class-ID: 0e02 serial: <filter>
Device-4: Microsoft LifeCam Studio
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 045e:0772
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 3840x2160 display-ID: 0
Monitor-1: DP-2 pos: primary,left model: Samsung SyncMaster
serial: <filter> built: 2009 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: DP-4 pos: right model: Dell UZ2715H serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 83 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: HDMI-A-4 pos: right model: Lontium semi serial: <filter>
built: 2020 res: mode: 3840x2160 hz: 30 scale: 200% (2) to: 1920x1080
dpi: 813 gamma: 1.2 size: 3840x2160mm (151.18x85.04") diag: 139mm (5.5")
ratio: 15:9, 16:9 modes: max: 3840x2160 min: 640x480
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.4.321 layers: 17 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 580.95.05 device-ID: 10de:2489
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics 770
(ADL-S GT1) driver: mesa intel v: 25.2.4-arch1.1 device-ID: 8086:4680
surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM 20.1.8)
de: kscreen-console,kscreen-doctor gpu: corectrl, gputop, intel_gpu_top,
lsgpu, lact, nvidia-settings, nvidia-smi wl: wayland-info,wlr-randr
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Conexant Systems (Rockwell) DELL UZ2715H
lanes: 1 mode: 1.1 bus-ID: 1-12.2:12 chip-ID: 0572:141c class-ID: 0300
API: ALSA v: k6.17.1-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF-ID-1: br-1f7862558da6 state: down mac: <filter>
IF-ID-2: br-7bfc84ea431e state: down mac: <filter>
IF-ID-3: br-82d31aa0b51e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-960c3623af4c state: down mac: <filter>
IF-ID-5: br-b787944b7593 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: br-b90412b2529c state: down mac: <filter>
IF-ID-7: br-c3a5729d4cf6 state: down mac: <filter>
IF-ID-8: br-e0cf0c4bc03a state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-9: br-e9c38ec2b98c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-10: docker0 state: down mac: <filter>
IF-ID-11: veth03c4a4f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth4ccbab3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth5f3d8a9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethe85a946 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: virbr0 state: down mac: <filter>
IF-ID-16: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.37 TiB used: 2.97 TiB (46.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 705.27 GiB (38.6%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:3
used: 636 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:2
used: 705.27 GiB (38.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:3
maj-min: 259:3
maj-min: 259:3
ID-1: swap-1 type: zram size: 31.08 GiB used: 137.3 MiB (0.4%)
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 44.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 9.43 GiB (30.4%)
Processes: 620 Power: uptime: 3h 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: 2698 pm: pacman pkgs: 2681 libs: 619 tools: octopi,pacseek,paru
pm: flatpak pkgs: 17 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14
Shell: Bash v: 5.3.3 default: fish v: 4.1.2 running-in: kitty inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2024-10-16
Garuda release: 240428
Last full system update: 2025-10-08
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
23/24 checks run in 0.73 seconds ⌛
Powered by garuda-health 🦅
Many thanks!!
