Hello!
First of all, I am in love with Garuda, I've installed it some hours and have to say it's the best looking desktop I've ever seen, everything ready after installation. Thank you, I really appreciate it.
The one thing that I found I didn't like was that HTOP is reporting the temperature in Fahrenheit, and I would like it in Celsius. I have been searching for a while and have found nothing relevant to my problem, so I come here in hopes that someone will know the answer.
Thank you
Kernel: 5.15.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1c0966bd-a51c-4456-82ac-748eaaa86e91 rw rootflags=subvol=@
quiet
cryptdevice=UUID=89f671d1-1a68-4e93-8fb1-c4429b039bce:luks-89f671d1-1a68-4e93-8fb1-c4429b039bce
root=/dev/mapper/luks-89f671d1-1a68-4e93-8fb1-c4429b039bce splash
resume=/dev/mapper/luks-1dbce9c8-2c8a-4cea-9245-c04812506ce0 loglevel=3
Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.00
date: 04/11/2020
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2954 high: 4340 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2633 2: 2900
3: 2421 4: 2571 5: 2457 6: 2466 7: 2499 8: 4305 9: 2560 10: 2798 11: 2897
12: 3934 13: 2634 14: 2462 15: 3394 16: 4340 bogomips: 118384
STIBP: disabled, RSB filling
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Gigabyte
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 24:00.0
chip-ID: 10de:1b06 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 3440x1440 s-dpi: 106 s-size: 824x352mm (32.4x13.9")
s-diag: 896mm (35.3")
Monitor-1: DP-2 res: 3440x1440 dpi: 107 size: 819x346mm (32.2x13.6")
diag: 889mm (35")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 24:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2e:00.3 chip-ID: 1022:1457
Device-3: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 1b3f:2008
Sound Server-1: ALSA v: k5.15.8-zen1-1-zen running: yes
v: kernel port: e000 bus-ID: 26:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 5.01 TiB used: 2 TiB (39.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS3030 1TB SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CS303225
temp: 25.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: SSD 960 PRO 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 4B6QCXP7 temp: 18.9 C scheme: GPT
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
model: WD20EARS-00MVWB0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
ID-1: / raw-size: 896.72 GiB size: 896.72 GiB (100.00%)
used: 26.92 GiB (3.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-89f671d1-1a68-4e93-8fb1-c4429b039bce
ID-3: /home raw-size: 896.72 GiB size: 896.72 GiB (100.00%)
ID-4: /var/log raw-size: 896.72 GiB size: 896.72 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.72 GiB size: 896.72 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 34.49 GiB used: 0 KiB (0.0%)
mapped: luks-1dbce9c8-2c8a-4cea-9245-c04812506ce0
System Temperatures: cpu: 32.9 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): fan-2: 1514 fan-3: 1486 fan-4: 1511 gpu: nvidia
fan: 21%
Processes: 395 Uptime: 42m wakeups: 0 Memory: 31.36 GiB
used: 5.3 GiB (16.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1894 lib: 541 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
