I will start with this…
╭─fenris@fenris in ~ took 70ms
╰─λ garuda-inxi
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8adfdab2-f46f-4dc9-bec4-6c286c843cff rw rootflags=subvol=@
quiet resume=UUID=a72d297c-8ad5-4e2f-9483-375f636e64b4 loglevel=3 ibt=off
Type: Desktop System: AZW product: MINI S v: N/A
Mobo: AZW model: MINI S v: 10 serial: <superuser required> UEFI: American
Megatrends LLC. v: ADLNV104 date: 02/06/2023
Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 90%
rechargeable: yes status: discharging
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x12
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1031 high: 1184 min/max: 700/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1184 2: 1180 3: 700
4: 1063 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: HDMI-A-1,HDMI-A-2 empty: none bus-ID: 00:02.0 chip-ID: 8086:46d1
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:9
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 867x285mm (34.13x11.22")
s-diag: 913mm (35.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: bottom-l model: HKC TV
serial: <filter> built: 2015 res: 1360x768 hz: 60 dpi: 45 gamma: 1.2
size: 760x450mm (29.92x17.72") diag: 806mm (31.7") ratio: 16:9, 15:9
modes: max: 1360x768 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,top-right model: HP LA2206
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 23.3.3-arch1.1
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
Device-1: Intel driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-3.2:4 chip-ID: 0d8c:0102 class-ID: 0300
Device-3: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-3.3:7 chip-ID: 0c76:2018 class-ID: 0300
Device-4: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:5
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u3u1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 110.77 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EHFM90.1 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0202 scheme: GPT
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 16.02 GiB (3.2%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
used: 584 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 1.06 TiB size: 1.06 TiB (100.00%)
used: 79.62 GiB (7.4%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
used: 16.02 GiB (3.2%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.4 GiB used: 5.36 GiB (34.8%)
ID-2: swap-2 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 341 Uptime: 23h 27m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.4 GiB used: 13.64 GiB (88.5%) Init: systemd v: 255
pm: pacman pkgs: 1479 libs: 418 tools: pamac,paru,yay Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-12
Last full system update: 2024-01-14 ↻
Failed units: vmware-workstation-server.service vmware.service logrotate.timer man-db.timer shadow.timer updatedb.timer
╭─fenris@fenris in ~ took 5s
╰─λ
So I get my printers and scanner setup, printers work fine. I put the test page into the scanner to give the system something to test scan and I start getting these issues.
╭─fenris@fenris in ~ as 🧙 took 12s
[🔴] × hp-scan
HP Linux Imaging and Printing System (ver. 3.23.12)
Scan Utility ver. 2.2
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
| SELECT DEVICE |
Num Scan device URI
0 v4l:/dev/video0
1 airscan:w0:HP LaserJet Pro MFP M127fn
Enter number 0...1 for device (q=quit) ?1
warning: No destinations specified. Adding 'file' destination by default.
Using device airscan:w0:HP LaserJet Pro MFP M127fn
Opening connection to device...
Resolution: 300dpi
Mode: gray
Compression: JPEG
Scan area (mm):
Top left (x,y): (0.000000mm, 0.000000mm)
Bottom right (x,y): (215.899994mm, 0.000015mm)
Width: 215.899994mm
Height: 0.000015mm
Destination(s): file
Output file:
warning: File destination enabled with no output file specified.
Setting output format to PNG for greyscale mode.
warning: Defaulting to '/home/fenris/hpscan001.png'.
Warming up...
Scanning...
error: SANE: Invalid argument (code=4)
Closing device.
╭─fenris@fenris in ~ as 🧙 took 32s
So I go and look up some stuff about scanners on the Arch forum, thought I would try out xscan to see if that would work (sudo pacman -Syu xscan). It loaded but it wouldn’t detect the scanner. So then I do this to see if the scanner could still be detected, and this is the results…
╰─λ hp-scan
Using device v4l:/dev/video0
error: Failed to get the source from device.
File "/usr/bin/hp-scan", line 994, in <module>
if len(source_option) == 1 and 'ADF' in source_option:
NameError: name 'source_option' is not defined
╭─fenris@fenris in ~ as 🧙 took 6s
I realized I made a big mess here so I do sudo pacman -R xsane and sudo rm -rf ~/.sane/xsane as the installation actually told me to do that if I experienced any problems. Then I noticed hp-scan gives me the same results.
So in otherwords…I really made a mess of my scanner
