I will just start with this…
╭─fenris@fenris in ~ as 🧙 took 0s
╰─λ sudo garuda-inxi
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4bf0d9ca-8f27-4679-8b43-3a354dfc3679 rw rootflags=subvol=@
quiet rd.luks.uuid=bea4912e-5a23-42eb-9d27-82a419d47ffd
rd.luks.uuid=b03a83d6-92ca-4ba6-9859-c3ad1f02206e
resume=/dev/mapper/luks-b03a83d6-92ca-4ba6-9859-c3ad1f02206e loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
Type: Mini-pc Mobo: AZW model: EQ serial: N/A
uuid: 68ce8b00-6aeb-11ef-8ec5-a4a2b6b92601 UEFI: American Megatrends LLC.
v: FP7T107 date: 07/22/2024
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
Speed (MHz): avg: 400 min/max: 400/4935 boost: enabled
base/boost: 3300/4925 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400
6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 105405
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
active: HDMI-A-1,HDMI-A-2 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 41.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.1.4:13
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 868x286mm (34.17x11.26")
s-diag: 914mm (35.98")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: left model: HKC TV
serial: <filter> built: 2015 res: 1360x768 hz: 60 dpi: 45 gamma: 1.2
size: 760x450mm (29.92x17.72") diag: 806mm (31.7") ratio: 16:9, 15:9
modes: max: 1360x768 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,right model: HP LA2206
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen) device-ID: 1002:1681
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-3.1.1:10 chip-ID: 0c76:2018 class-ID: 0300
Device-5: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
Device-6: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-3.2:14 chip-ID: 0d8c:0102 class-ID: 0300
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: down mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 8087:0029
Local Storage: total: 1.82 TiB used: 433.95 GiB (23.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 34.9 C
ID-1: / raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
used: 218.35 GiB (24.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 254:1 mapped: luks-bea4912e-5a23-42eb-9d27-82a419d47ffd
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-4: /var/log raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 909.97 GiB size: 909.97 GiB (100.00%)
ID-1: swap-1 type: partition size: 21.25 GiB used: 0 KiB (0.0%)
mapped: luks-b03a83d6-92ca-4ba6-9859-c3ad1f02206e
ID-2: swap-2 type: zram size: 19.31 GiB used: 8.05 GiB (41.7%)
System Temperatures: cpu: 44.5 C mobo: 33.5 C gpu: amdgpu temp: 44.0 C
Memory: total: 20 GiB available: 19.31 GiB used: 12.41 GiB (64.3%)
Processes: 546 Power: uptime: 6d 17h 51m states: freeze,mem,disk
reboot, suspend, test_resume image: 7.71 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 256
Packages: pm: pacman pkgs: 1666 libs: 446 tools: pamac,paru,yay Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
System install date: 2024-10-21
Last full system update: 2024-10-25 ↻
Failed units: vmware.service
╭─fenris@fenris in ~ as 🧙 took 3s
╰─λ
So I have this HP MFP M127fn printer/scanner attached to my network. It works nicely as a printer, and the Document Scanner in Garuda see’s the scanner (it also shows up in hp-scan) but it errors out when you try to scan something…
I will show you some pictures:
What it looks like in hp-scan:
╰─λ hp-scan
/usr/bin/hp-scan:255: SyntaxWarning: invalid escape sequence '\*'
("", "where <dest_list> is a comma separated list containing one or more of: 'file'\*, ", "option", False),
/usr/bin/hp-scan:257: SyntaxWarning: invalid escape sequence '\*'
("Scan mode:", "-m<mode> or --mode=<mode>. Where <mode> is 'gray'\*, 'color' or 'lineart'.", "option", False),
/usr/bin/hp-scan:274: SyntaxWarning: invalid escape sequence '\*'
("", "where <units> is 'mm'\*, 'cm', 'in', 'px', or 'pt' ('mm' is default).", "option", False),
HP Linux Imaging and Printing System (ver. 3.24.4)
Scan Utility ver. 2.2
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
| SELECT DEVICE |
Num Scan device URI
0 v4l:/dev/video0
1* hpaio:/net/HP_LaserJet_Pro_MFP_M127fn?ip=192.168.1.105
Enter number 0...1 for device (q=quit, <enter>=default: 1*) ?1
warning: No destinations specified. Adding 'file' destination by default.
Using device hpaio:/net/HP_LaserJet_Pro_MFP_M127fn?ip=192.168.1.105
Opening connection to device...
error: SANE: Error during device I/O (code=9)
╭─fenris@fenris in ~ as 🧙 took 21s
I looked at this particular Arch Linux post [SOLVED] Troublesome HP printer scanner / Kernel & Hardware / Arch Linux Forums but I’m not really able to make head way of what is happening there.
Any idea’s? I understand this is a temperamental printer, it’s one of HP’s engineering failures but I’m open to advice. ![]()
