So i have an HP printer the “Deskjet f2480” model.
Tried to add it using the printer app but looking thru the drivers, the needed driver isn’t there.
Tried to use a different driver but doesn’t work.
Went to check the HP website only to end up on this site telling me to download and run HPLIP.
Running it doesn’t do anything, not even in konsole.
Does anyone have any alternatives or fix? I apparently have one of the most obscure printers on earth.
<kbd>reverb@MSI in ~
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_MONETARY = "nl_BE.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_MEASUREMENT = "nl_BE.UTF-8",
LC_TIME = "en_GB.UTF-8",
LC_NUMERIC = "en_GB.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=09c39b21-943d-4299-817b-7740f7f1eacf rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: Micro-Star product: GL62M 7REX v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 33.0 Wh (94.6%) condition: 34.9/42.4 Wh (82.4%)
volts: 12.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3399 high: 3400 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3399 8: 3400 bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony USB 2.0 Webcam Device driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:10
chip-ID: 04f2:b521 class-ID: 0e02 serial: <filter>
gpu: i915,nvidia d-rect: 2355x864 display-ID: 0
Monitor-1: HDMI-A-2 pos: right res: 819x614 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1536x864 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 11.33 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 Ti driver: nvidia
v: 545.29.06 device-ID: 10de:1c8c surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.3.2-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: HP HyperX QuadCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 03f0:0491 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:9 chip-ID: 8087:0aa7
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.03 TiB used: 322.02 GiB (30.6%)
model: MZVLW128HEGR-00000 size: 119.24 GiB block-size: physical: 512 B
fw-rev: CXB7401Q temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 35.12 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.6 GiB used: 84.2 MiB (0.7%) priority: 100
System Temperatures: cpu: 72.0 C pch: 51.5 C mobo: N/A
Processes: 280 Uptime: 1h 53m wakeups: 1 Memory: total: 12 GiB
available: 11.6 GiB used: 5.92 GiB (51.0%) Init: systemd v: 255
pm: pacman pkgs: 1543 libs: 444 tools: octopi,pamac,paru,yay Shell: fish
v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-04
Last full system update: 2024-01-07 ↻
</kbd>
