HP Envy x360 microphone mute button not working
Hello,
Microphone mute button seems to be registering correct event, however it will just mute and unmute quickly after press.
I have been researching this issue on Arch forums, KDE forums and with ChatGPT 4o. Unfortunately I have not been able to get correct solution. This is the ONLY problem I have with Garuda and it is driving me nuts xD.
Lets get to the details - Shortcut is mapped correctly in KDE settings > shortcuts.
in config file
grep -i “mute” ~/.config/kglobalshortcutsrc
mic_mute=Microphone Mute,Microphone Mute\tMeta+Volume Mute,Mute Microphone
mute=Volume Mute,Volume Mute,Mute
But if I try to showkey I get basicaly two keycodes on press. Which I suspect can be the core of issue - however I do not know how to unmap that one particular keycode (190)
sudo showkey
kb mode was ?UNKNOWN?
[ if you are trying this under X, it might not work
since the X server is also reading /dev/console ]
press any key (program terminates 10s after last keypress)…
keycode 28 release
keycode 190 press
keycode 190 release
keycode 248 press
keycode 248 release
I tried
setkeycodes e002 248
  • did not work
tried to edit xmodmap - which got reverted back to state bellow
xmodmap -pke | grep 190
keycode 190 = Redo NoSymbol Redo
xmodmap -pke | grep 248
keycode 248 =
tried to manually edit KDE config even tho I knew that was blindshot.
tried solution I found on this forum for the mute button
sudo pacman -S alsa-utils sudo systemctl enable alsa-restore sudo systemctl start alsa-restore
Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b88c5f94-4900-4f5c-8a1a-fb7ae11772e6 rw rootflags=subvol=@
quiet resume=UUID=88557f26-385d-4d91-aeee-d3544ac5117c loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ay0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 876E v: 12.54 serial: <superuser required>
part-nu: 187M5EA#BCM uuid: <superuser required> UEFI: Insyde v: F.24
date: 09/07/2023
ID-1: BAT1 charge: 41.6 Wh (100.0%) condition: 41.6/51.0 Wh (81.7%)
volts: 12.8 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX
Anywhere 2S serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x8600109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 31940
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 47.0 C
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.11.3-zen1-1-zen) device-ID: 1002:1636
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.4-arch1.1
device-ID: 1002:1636 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.4-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
API: ALSA v: k6.11.3-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0bda:b00c
Local Storage: total: 953.87 GiB used: 9.39 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV1T02 KIOXIA size: 953.87 GiB block-size: physical: 512 B
fw-rev: HP00AE00 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 937.06 GiB size: 937.06 GiB (100.00%)
used: 9.39 GiB (1.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 937.06 GiB size: 937.06 GiB (100.00%)
ID-4: /var/log raw-size: 937.06 GiB size: 937.06 GiB (100.00%)
ID-5: /var/tmp raw-size: 937.06 GiB size: 937.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.01 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.51 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 68.1 C mobo: N/A gpu: amdgpu temp: 48.0 C
Memory: total: 16 GiB note: est. available: 15.01 GiB used: 4.11 GiB (27.4%)
Processes: 281 Power: uptime: 59m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 5.99 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1411 libs: 466 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date:     2024-10-15
Last full system update: 2024-10-16 ↻
Allow me to answer my own question.
For some reason whole problem was indeed that mute key on my laptop is generating two keycode events.
190 (KEY_F20)
and 248 (mute microphone)
I was searching like crazy how to delete, remove, yoink or nuke that particular keycode event from this planet. But at the end all I needed to is to go to KDE system settings > keyboard > Key Bindings > Function keys > check Use F13-F24 as usual function keys.
Core problem is still not solved as mute key is still generating 2 key events mentioned above, but because “KEY_F20” is no longer mapped to event keycode 190 i can mute and unmute my microphone.
