I want to edit the light.sh script in ~/.config/sway/scripts. i want to add my cordinates so it will be 4000k at night. i’m not sure what they are currently, but it’s brighter than 4000k. i assume that is because it’s not using my coordinates?
i have searched online, read through arch wiki, looked at google and github. i also read the page you posted below, before and after it was posted. i don’t see it mentioned anywhere how to use wlsunset besides manually, which i can do but want to do it automatically. i think that is why y’all used a script, and why i want to edit it. although i am not sure if that is the best way to go about it.
i see 4xx client error but i’m not sure what i need to do to not have 4xx client error. should i try and understand how to script first? and i tried to provide the 412 preconditions. i can add more or do more if it is needed, i’m not sure what i should do next though.
i’m sorry i broke the rules.
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f0ee726f-b78c-4fed-b27f-2bb9de98ea04 rw rootflags=subvol=@
Desktop: Sway v: 1.8.1 with: waybar tools: swayidle avail: swaylock vt: 1
lm: greetd Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX v: x.x
Megatrends LLC. v: F3 date: 01/20/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF8
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 scaling: driver: intel_pstate
bogomips: 121596
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: Sapphire
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ef
Display: wayland server: Xwayland v: 23.2.4 compositor: Sway v: 1.8.1
driver: gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: 27E1QA serial: <filter> built: 2022
res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2 scale: 1
max: 2560x1440 min: 720x400
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6650 XT (RADV NAVI23) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:73ef surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: FDUCE PRO AUDIO MADE driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8888:1234
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 3.64 TiB used: 185.23 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler G3
size: 3.66 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 185.23 GiB (9.9%)
used: 185.23 GiB (9.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: 25.0 C gpu: amdgpu temp: 32.0 C
mem: 30.0 C
Memory: total: 32 GiB available: 31.21 GiB used: 3.43 GiB (11.0%)
Processes: 404 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB Init: systemd v: 255
Packages: pm: pacman pkgs: 1408 libs: 458 tools: paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: terminator inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-11
Last full system update: 2024-02-22
