… how to use garuda-qtile-settings; i’m on garuda cinnamon and i have installed the garuda-qtile-settings and qtile packages to use qtile; but when i boot into qtile it is barely ugly !!!
Probably you just need to copy the files over from /etc/skel.
Create a new user, log in as them, and see if Qtile looks any different.
After installing garuda-qtile-settings, you’ll need to copy the config files to your home directory. Check if there’s a .config/qtile folder in your home directory. If not, copy the config from /etc/skel/.config/qtile. Restart Qtile after that, and it should look better with the Garuda theme applied.
