How to use and monitor Dedicated GPU in Garuda Linux
I want to use my dedicated GPU that is AMD Radeon 8600M (I am not sure about the 8600M part). I want to use it in games like Minecraft for better Fps in windows I was able to use it but when I shifted to Garuda Linux I am not seeing the GPU in system monitor and cannot find how to use it on yt
Welcome to the forum
Can you provide your
as per the forum template
install nvtop, then you can see how the GPU works or not
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d10db76e-8505-4cea-a147-561ab09907c9 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0889100000005B10000600000 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1970 v: 95.32 serial: <superuser required>
part-nu: E4X57PA#ACJ uuid: <superuser required> UEFI: Insyde v: F.21
date: 12/04/2013
ID-1: BAT0 charge: N/A condition: N/A volts: 12.6 min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: not charging
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3012 high: 3070 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2993 2: 2993 3: 2993
4: 3070 bogomips: 20752
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380 temp: 63.0 C
compositor: kwin_wayland driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: crocus,radeonsi gpu: i915,radeon
display-ID: 0
Monitor-1: LVDS-1 res: 1366x768 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms:
device: 0 drv: radeonsi device: 1 drv: crocus device: 2 drv: swrast
surfaceless: drv: radeonsi wayland: drv: crocus x11: drv: crocus
inactive: gbm
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.1.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
HD Graphics 4000 (IVB GT2) driver: mesa intel v: 24.1.4-arch1.2
device-ID: 8086:0166 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
chip-ID: 8086:0082 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-3: Ralink RT5370 Wireless Adapter driver: rt2800usb type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 148f:5370
IF: wlp0s20u1 state: up mac: <filter>
Local Storage: total: 167.68 GiB used: 21.38 GiB (12.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BF180A4H
size: 167.68 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: LH6i scheme: GPT
ID-1: / raw-size: 167.38 GiB size: 167.38 GiB (100.00%)
used: 21.38 GiB (12.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 167.38 GiB size: 167.38 GiB (100.00%)
ID-4: /var/log raw-size: 167.38 GiB size: 167.38 GiB (100.00%)
ID-5: /var/tmp raw-size: 167.38 GiB size: 167.38 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 79.0 C mobo: N/A gpu: radeon temp: 63.0 C
Memory: total: 8 GiB available: 7.65 GiB used: 2.24 GiB (29.3%)
Processes: 214 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1821 libs: 538 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-27
Last full system update: 2024-07-28
Idk why but it only shows my integreted GPU
  • Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text.
Done :slight_smile:
To use your dGPU you have to prepend the command with DRI_PRIME=1
https://wiki.archlinux.org/title/PRIME#For_open_source_drivers_-_PRIME
Otherwise, the iGPU is used by default.
Can u pls explain what to do step by step cuz I just started using linux day before yesterday only. Also really thanks for helping me
Sorry, I don’t have much time.
Try from terminal
DRI_PRIME=1 minecraft-launcher
I’m not 100% sure about the launcher name, but that’s a typical example.
If it works, search for desktop files to make it prrsistent.
I tried this but idk why but it installed the minecraft launcher and besides i want to use it on another launcher and when i was watching a video on how to use dedicated gpu, it showed that i should do xrandr --listproviders and in the video it showed their list of graphics card but in my case it showed 0 and nothing
Update I tried the Gri prime thing and I got the Radeon GPU to work and I could check it with the Radeontop application. But can anyone tell me if I want to use the dri prime function for a specific app but I don’t know what it’s name is then how do I get the application’s name that can work in Konsole with the dri prime function
