How to upgrade graphics card from 2060 to 4070?
Hello all,
my brand new shiny 4070 arrived today :grinning:
How do i install it, because i dont think it uses the same drivers as my 2060 i cant just swap the card and boot?
please can someone tell me the correct process
thanks
It probably can use the same drivers.
What version of the drivers are you using now?
╰─λ nvidia-smi
Mon Jun 19 11:31:50 2023
| NVIDIA-SMI 535.54.03 Driver Version: 535.54.03 CUDA Version: 12.2 |
Yes you can just install the new card and it will work, they use the same driver
all working thanks everyone
