I have kinda half de-dragonized my KDE, changing the theme and icons, but leaving the whole desktop layout mostly intact. That means, window buttons on the left, and most importantly, global menu style - the app menu being integrated into the top Plasma panel:
My problem on this small laptop screen is tiny click targets (I hate them) and I prefer managing the desktop with mouse gestures, keyboard shortcuts etc. Mostly for unmaxizing a window, I’m used to dragging a window by the title bar - except that doesn’t work in a global menu situation, where the title bar is part of Plasma panel.
My question: Is there any Plasma/KWin/etc. setting or method for unmaximizing (possibly also positioning) windows with my mouse, that will give me a bigger click target ?
I know about the Meta + PgUp keyboard shortcut, what I’m missing is a mouse method.
╰─λ garuda-inxi
Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=dc229e5a-50c1-478a-b84b-e60401e4d6c0 rw rootflags=subvol=@
resume=UUID=258393c9-45c2-4f11-9c89-8fb56cf7d7ab loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: TUXEDO model: N141CU serial: <superuser required> UEFI: INSYDE
v: 1.07.07RTR1 date: 11/08/2019
ID-1: BAT0 charge: 30.5 Wh (81.8%) condition: 37.3/35.3 Wh (105.5%)
volts: 11.6 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2500 high: 2503 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 2500 2: 2500 3: 2500
4: 2500 5: 2502 6: 2503 7: 2501 8: 2500 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b649
class-ID: 0e02
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
device-ID: 8086:9b41 memory: 14.96 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9b41 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api with: aoss
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 5000 bus-ID: 3b:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0f1 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 40:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp64s0 state: up mac: <filter>
IF-ID-1: wwp0s20f0u2c2 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Local Storage: total: 953.87 GiB used: 131.65 GiB (13.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 28.9 C scheme: GPT
ID-1: / raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
used: 131.65 GiB (14.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-4: /var/log raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 47.0 C pch: 45.0 C mobo: N/A
Processes: 277 Uptime: 12m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.32 GiB used: 5.01 GiB (32.7%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1720
pm: pacman pkgs: 1714 libs: 512 tools: pamac,paru pm: flatpak pkgs: 6
Shell: fish v: 3.6.2 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-10-28
Last full system update: 2023-12-21
Failed units: nmb.service
