I just recently tried to install OpenVPN following this which unfortunately failed because it couldn't connect to the server. The VPN was installed in spite of the errors during installation. The VPN is not working now so I want to uninstall it and I was wondering how.
Thanks in advance for your assistance.
Kernel: 6.4.7-zen1-3-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3852ea8d-d2e5-4042-9059-7499964ca656 rw rootflags=subvol=@
resume=UUID=c0e91ddc-7c34-4cbd-9a88-09820fbb8ea9 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515JP_R565JP
Mobo: ASUSTeK model: X515JP v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X515JP.308 date: 07/04/2022
ID-1: BAT0 charge: 36.3 Wh (100.0%) condition: 36.3/37.1 Wh (97.8%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 3
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1459 high: 1500 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1500 2: 1179 3: 1500
4: 1500 5: 1500 6: 1500 7: 1500 8: 1500 bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 535.xx+ status: current (as of 2023-07) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d16
class-ID: 0302 temp: 46.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 322e:2103
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel Iris Plus Graphics
(ICL GT2) direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.4.7-zen1-3-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 37.09 GiB (7.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: GPT
ID-1: / raw-size: 350 GiB size: 350 GiB (100.00%) used: 18.07 GiB (5.2%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 110.43 GiB size: 110.43 GiB (100.00%)
used: 19.02 GiB (17.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 350 GiB size: 350 GiB (100.00%)
used: 18.07 GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 350 GiB size: 350 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.5 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nouveau temp: 46.0 C
Fan Speeds (RPM): cpu: 3200
Processes: 300 Uptime: 3h 33m wakeups: 1 Memory: total: 8 GiB note: est.
available: 7.5 GiB used: 4.26 GiB (56.7%) Init: systemd v: 254
pm: pacman pkgs: 1801 libs: 518 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-15
Last full system update: 2023-08-04
