Hello.
So I m running a MSI GF63 laptop, I have a dual boot installed with Windows 11 on other partition . Sometimes when i open my lid after a long period of time (usually first time in the morning), I was using windows before but it boots from the start, meaning I see the boot menu, I can successfully boot into garuda too, can't use the wifi, everything else works. And when i decide to restart the system from linux and then boot into windows, all my stuff from last night is still there.
What i want is to achieve this in linux, meaning a button or command of sorts that will save my current state (in linux), and allow me to reach my boot menu so I can boot into windows (to play some games maybe) without losing all the windows and stuff i had opened on different screens. And when I log off windows, I can just resume the work that I left in linux.
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=fa48165e-1db5-4264-968d-2cbe91a74909 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: GF63 Thin 10SC v: REV:1.0
Mobo: Micro-Star model: MS-16R5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R5IMS.104 date: 08/30/2021
ID-1: BAT1 charge: 28.8 Wh (59.9%) condition: 48.1/51.3 Wh (93.7%)
volts: 11.8 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 510.60.02
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
chip-ID: 10de:1f9d class-ID: 0302
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2020 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.1
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 1.14 TiB used: 658.07 GiB (56.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AI1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
ID-1: / raw-size: 100.08 GiB size: 100.08 GiB (100.00%)
used: 29.21 GiB (29.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 28.1 MiB (9.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100.08 GiB size: 100.08 GiB (100.00%)
ID-4: /var/log raw-size: 100.08 GiB size: 100.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 100.08 GiB size: 100.08 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C pch: 57.0 C mobo: N/A
Processes: 359 Uptime: 26m wakeups: 2 Memory: 7.59 GiB
used: 3.85 GiB (50.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1413 lib: 353 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-01-25
Last full system update: 2022-04-29
