Small issue:
When I pair my phone with my Computer via Bluetooth, it defaults to the Audio profile.
I don’t know how to change it to File Transfer,
so file sending only works when initiated from the computer.
I would like to be able to toggle between Audio and File modes.
In other words by default the audio of my phone will be send to my computer,
and sending files from my phone won’t work in that case.
Device details:
Phone: Oneplus 9 running LineageOS
garuda-inxi:
Kernel: 6.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d4f8c435-c4aa-4c47-9c51-9e081d8a8476 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-F GAMING v: Rev X.0x
Firmware: UEFI vendor: American Megatrends v: 3004 date: 07/12/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
Speed (MHz): avg: 4700 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 4700 2: 4700 3: 4700 4: 4700 5: 4700 6: 4700
7: 4700 8: 4700 9: 4700 10: 4700 11: 4700 12: 4700 bogomips: 88796
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: EVGA driver: nvidia
v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2482 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:4
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung U28E590 serial: <filter> built: 2017
res: mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 dpi: 160
gamma: 1.2 size: 608x345mm (23.94x13.58") diag: 699mm (27.5") ratio: 16:9
modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
API: Vulkan v: 1.4.335 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 590.48.01 device-ID: 10de:2482
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.4-arch1.1 (LLVM 21.1.6)
Device-2: NVIDIA GA104 High Definition Audio vendor: EVGA
API: ALSA v: k6.18.6-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:3
Local Storage: total: 5.01 TiB used: 2.62 TiB (52.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXP7 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUA723020ALA641
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: MBR
model: WD30EZRZ-00GXCB0 size: 2.73 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 195.29 GiB size: 195.29 GiB (100.00%)
used: 72.66 GiB (37.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 85.74 GiB size: 85.74 GiB (100.00%)
used: 49.55 GiB (57.8%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 195.29 GiB size: 195.29 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.29 GiB size: 195.29 GiB (100.00%)
ID-2: swap-2 type: partition size: 48.83 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 37.0 C mobo: N/A
Memory: total: 32 GiB available: 31.27 GiB used: 9.19 GiB (29.4%)
Processes: 436 Power: uptime: 1h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: 2176 pm: pacman pkgs: 2159 libs: 515 tools: octopi,pamac,paru
pm: flatpak pkgs: 17 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash
v: 5.3.9 default: fish v: 4.3.3 running-in: konsole inxi: 3.3.40
Garuda (2.12.3-2):
System install date: 2025-10-04
Garuda release: 251002
Last full system update: 2026-01-27
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
25/26 checks run in 0.77 seconds ⌛
Powered by garuda-health 🦅
