Hi,
So I created a new user and found that Paleofetch doesn't automatically start with the terminal?
How do I start it?
I tried opening ~/.bashrc in nano with Sudo privileges and writing in "paleofetch" in there, but that didn't work!
Any ideas?
Thanks,
If you use fish, you should configure it (config.fish) according to this post:
Do not use sudo in your ~/ directories.
check with
find $HOME ! -user $USER -type f
remove root with
sudo chown -R $USER: $HOME
Second, give micro a try
system
Closed
4
