Is there a straight forward way to setup bluetooth. It doesn't seem to recognize my bluetooth hardware at all, it gives a "no devices detected" message in the bluetooth menu.
I"ve attempted to follow the instructions on the regular arch wiki, installed bluez and bluez-utils, etc. But nothing works.
I have a Librem 15 and I'm using KDE Gaming Dragonized Edition.
Did you check status and enable BT with sytemctl?
I ran this command.
sudo systemctl enable bluetooth
But it did not help.
The gaming edition doenst work well with drivers at all.
I enabled all of these services in the Grauda manager. Still no dice
Should I just switch to something else?
Again...
