I dont see any options in gui. First I got only front left and right working right away. then changed number of chanels in alsamixer
and run sudo alsactl store
- now i have no sound at all.
I need some guide for this- don't even know where to start can't find any guide for garuda and arch tutorials assume you use pulseaudio
Kernel: 6.2.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9d2d8e56-57be-422a-a3c9-6b6a330c3948 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-P II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 09/26/2019
Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
desc: 1x9 MiB
Speed (MHz): avg: 4685 high: 4907 min/max: 800/4300:4900 scaling:
driver: intel_pstate governor: performance cores: 1: 4899 2: 4907 3: 3600
4: 4900 5: 4899 6: 4907 bogomips: 43200
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ZOTAC driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b82 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1070
Ti/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound API: ALSA v: k6.2.1-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168
driver: btusb v: 0.8 bus-ID: 2-7:4 chip-ID: 0a12:0001 class-ID: e001
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 2-8:5 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci1 rfk-id: 1 state: up address: N/A
Local Storage: total: 2.74 TiB used: 2.18 TiB (79.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: SS0328D temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX001-1CM164
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
used: 305.95 GiB (64.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.56 GiB used: 1.11 GiB (7.1%)
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 79%
Processes: 290 Uptime: 8h 37m wakeups: 6 Memory: 15.56 GiB
used: 5.56 GiB (35.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 1996 libs: 548 tools: octopi,paru,yay Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-12-11
Last full system update: 2023-03-01 ↻
