How to set Plasma X11 as default?
Hi. Linux boots Wayland by default. But OBS studio won’t work and says “Device not connected or not detected” in case if I want to stream (screencapture). So I have to log out, change to X11 and log in back everytime I restart or Shutdown my PC.
Solution I found for Wayland to run with OBS is not easy, need to install lot’s of packages (like pipewire) and edit config files which a risk to ruine system. So as far X11 work well for me I don’t have special desire to set up the Wayland.
Is it possible to change boot to X11 by default instead of Wayland?
Tnx
Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=162f422b-411b-4f26-9b23-eb689b33696b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
wm: kwin_wayland tools: avail: swayidle,swaylock vt: 2 dm: SDDM
Type: Desktop Mobo: Intel model: DQ67OW v: AAG12528-308
serial: <superuser required> uuid: <superuser required> BIOS: Intel
v: SWQ6710H.86A.0055.2011.0921.1044 date: 09/21/2011
Info: model: Intel Core i5-2400 bits: 64 type: MCP arch: Sandy Bridge
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3279 min/max: 1600/3400 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3279 2: 3279 3: 3279 4: 3279 bogomips: 24743
driver: i915 v: kernel arch: Gen-6 code: Sandybridge process: Intel 32nm
built: 2011 ports: active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:0102 class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: Sapphire driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-2 empty: DP-2,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 52.0 C
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,intel,vesa dri: radeonsi,crocus gpu: i915,amdgpu
d-rect: 2944x1848 display-ID: 0
Monitor-1: HDMI-A-2 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-2: VGA-1 pos: bottom-l res: 1024x768 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms:
device: 0 drv: crocus device: 1 drv: radeonsi device: 2 drv: swrast gbm:
drv: crocus surfaceless: drv: crocus wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6 compat-v: 3.3 vendor: amd mesa v: 24.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 LLVM 18.1.8 DRM 3.59 6.12.8-zen1-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: Sapphire driver: snd_hda_intel v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel 82579LM Gigabit Network driver: e1000e v: kernel port: f080
bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:3
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlan0 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 111.76 GiB (12.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 840H
scheme: MBR
ID-1: / raw-size: 117.92 GiB size: 117.92 GiB (100.00%)
used: 111.76 GiB (94.8%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 117.92 GiB size: 117.92 GiB (100.00%)
ID-3: /var/log raw-size: 117.92 GiB size: 117.92 GiB (100.00%)
ID-4: /var/tmp raw-size: 117.92 GiB size: 117.92 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
System Temperatures: cpu: 63.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1426
Memory: total: 32 GiB available: 31.23 GiB used: 3.9 GiB (12.5%)
Processes: 280 Power: uptime: 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2081 libs: 590 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
Garuda (2.6.26-1.1):
System install date:     2023-12-06
Last full system update: 2025-02-18
Apparently, you haven’t updated the system for a long time.
If you log in, change it, bottom left, it remeber the last boot to X11.
Do you mean Login Screen or Desktop?
This.
I don’t have this login screen at start up. I see those intel stuff, next is a boot menu (where I can chose linux, windows, snapshot etc), next is garuda logo and desktop. To access to login screen I need to got to shutdown/restart section and chose log out. Then I go to login screen and chaning DE to X11, but it is never remer seting this way.
How did you remove it?
Auto login?
Boot time set to 0?
Change it :slight_smile:
System Settings → Colors & Themes → Login Screen (SDDM) → Behavior Button (top) → enable “Automatically log in” → with session: “Plasma (x11)” → Apply → Reboot.
I didn’t removed. It was since from beginning
Oh! It works!
After reboot OBS recognised everything.
Thanks a lot!
