kenmt
11 March 2024 02:17
1
Hello all, I just bought a monitor that support 144hz refresh rate, but in the GUI display config there is only options 50/60/120 Hz.
I tried to run the following commands:
xrandr --newmode "3440x1440_144.00" 1086.75 3440 3744 4128 4816 1440 1443 1453 1568 -hsync +vsync
xrandr --addmode DP-1 "3440x1440_144.00"
xrandr --output DP-1 --mode "3440x1440_144.00"
The commands ran successfully without error, but it doesn’t seem to work, the monitor is still running at 120hz.
here is the out put of xrandr -q
Screen 0: minimum 16 x 16, current 3440 x 1440, maximum 32767 x 32767
DP-1 connected primary 3440x1440+0+0 (normal left inverted right x axis y axis) 800mm x 330mm
3440x1440 119.98*+
1920x1440 119.97
1600x1200 119.82
1440x1080 119.92
1400x1050 119.90
1280x1024 119.83
1280x960 119.89
1152x864 119.77
1024x768 119.80
800x600 119.85
640x480 119.52
320x240 117.34
1920x1200 119.90
1680x1050 119.89
1440x900 119.94
1280x800 119.85
1152x720 119.73
960x600 119.74
928x580 119.55
800x500 119.47
768x480 119.71
720x480 119.65
640x400 119.64
320x200 117.55
2560x1440 119.95
2048x1152 119.96
1920x1080 119.93
1600x900 119.95
1368x768 119.83
1280x720 119.86
1024x576 119.85
864x486 119.69
720x400 119.54
640x350 119.24
3440x1440_144.00 143.91
here is the output of inxi -Fazy :
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4eccb87a-c76c-44cf-a5ac-a7072a6d1312 rw rootflags=subvol=@ quiet
video=DP-1:3440x1440@144 ibt=off
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 39.0 C
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.57 6.7.9-zen1-1-zen) device-ID: 1002:1638 memory: 500 MiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics driver: amd v: (AMD
proprietary shader compiler) device-ID: 1002:1638
surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM 17.0.6
256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM 17.0.6)
SGS
11 March 2024 08:46
2
Please, follow the template and post garuda-inxi.
It contains additional, useful information about the status of your system.
kenmt
11 March 2024 08:51
3
here is the output of garuda-inxi:
quiet video=DP-1:3440x1440@144 ibt=off
Type: Laptop System: win element product: MoreFine S500+ v: N/A
Mobo: N/A model: N/A serial: <superuser required> part-nu: MoreFine S500+
uuid: <superuser required> UEFI: American Megatrends LLC.
v: S013_V1.2_P3C3M43_MoreFine date: 11/03/2021
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2873 high: 4618 min/max: 400/4680 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3707 2: 3659 3: 3648
4: 400 5: 4618 6: 4579 7: 2510 8: 3652 9: 3650 10: 2210 11: 2509 12: 3650
13: 400 14: 3650 15: 2731 16: 400 bogomips: 105401
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 40.0 C
renoir LLVM 17.0.6 DRM 3.57 6.7.9-zen1-1-zen) device-ID: 1002:1638
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM 17.0.6)
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api
speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
wpa_supplicant
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 1.86 TiB used: 1.31 TiB (70.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S500PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: SN10613 temp: 40.9 C
ID-1: / raw-size: 1.61 TiB size: 1.61 TiB (100.00%) used: 1.31 TiB (81.0%)
used: 25.6 MiB (26.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.61 TiB size: 1.61 TiB (100.00%)
used: 1.31 TiB (81.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.61 TiB size: 1.61 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.61 TiB size: 1.61 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.8 C mobo: 42.0 C gpu: amdgpu temp: 40.0 C
Memory: total: 64 GiB note: est. available: 62.2 GiB used: 12.84 GiB (20.6%)
Processes: 406 Power: uptime: 3h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.86 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1546 libs: 400 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: kitty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-06-20
Last full system update: 2024-03-11 ↻
SGS
11 March 2024 08:53
4
First thing in KDE, reboot the system, a hint is the ↻
system
Closed
25 March 2024 08:54
5
