Hi, I'm not sure if this is a suitable place to ask, but I can't construct the right question to search for information in Google ![]()
I have a standard panel bar and placed a few System monitor widgets there. For some reason, the size of one widget is smaller than its content.
How I can set it a size to show the full text?
Kernel: 6.0.12-zen1-1.1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d542eccb-4cb8-4c14-9205-14a805521c37 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Desktop System: Micro-Star product: MS-7C35 v: 1.0
Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E2
date: 03/24/2021
Device-1: hid-dc:2c:26:04:73:b3-battery model: Keychron K2 serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4014 high: 4475 min/max: 2200/4757 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3696 2: 3604
3: 3900 4: 4154 5: 4363 6: 3596 7: 3993 8: 4176 9: 3900 10: 3900 11: 3900
12: 3900 13: 4475 14: 4277 15: 4475 16: 3929 bogomips: 124804
protection
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 14.0.6 DRM 3.48 6.0.12-zen1-1.1-zen) direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1.1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 931.51 GiB used: 125.1 GiB (13.4%)
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 47.9 C scheme: GPT
used: 125.1 GiB (13.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 532
Processes: 363 Uptime: 1h 14m wakeups: 1 Memory: 31.27 GiB
used: 4.4 GiB (14.1%) Init: systemd v: 252 default: graphical
pkgs: 1360 libs: 357 tools: paru,yay Shell: fish v: 3.5.1
Garuda (2.6.12-1):
System install date: 2022-12-20
Last full system update: 2022-12-21
