i am on alacritty.
i want to run tmux
while it is on i want to run echo hi
i tried tmux -c 'echo hi
but it just returns hi
(just like echo hi
it doesn't open tmux session.
❯ tmux -c 'echo hi'
hi
i am on alacritty.
i want to run tmux
(just like echo hi
❯ tmux -c 'echo hi'
hi
And you are already doing what you described, the command run inside tmux and then the tmux session is closed as soon as the command ends.
so if i run 'nnn' or something which doesn't end on it's own i should be able to see that on tmux interface. which i don't. it's like i didn't even types 'tmux -c'
i want to see my command output in the tmux interface.
Are you sure this is the right command?
-c shell-command
Execute shell-command using the default shell. If
necessary, the tmux server will be started to
retrieve the default-shell option. This option is
for compatibility with sh(1) when tmux is used as a
login shell.
How about this?
tmux new -s foo 'echo intmux; $SHELL'
Source: bash - How to run tmux with shell command - Stack Overflow
Why are you using -c?
Unless I'm missing something, tmux is normally used interactively to provide multiple windows within a single terminal session.
I use tmux all day long and don't close it.
