I love Garuda but some of the things are not useful to me; I prefer bash over zsh, I don't want/use conky or latte dock. Can someone tell me an easy way to respin Garuda to remove the packages and settings I don't need and include the ones I do?
Hey
What you are looking for is the garuda-tools. A basic how-to is available in the README of the repo. (need to install garuda-tools-iso-git)
You need to download iso-profiles as well, using these its easy to build own isos
You need to modify the garuda iso-profiles (copy the KDE one for example) which you downloaded to ~/iso-profiles, looking for profile.conf. Its possible to set the shell and a lot of other things there.
That requires you to build your own iso however, which is what I thought you wanted to do.
If you just want to change the shell and remove packages its easier to just change it via command line.
Thanks that's what I meant, I just didn't know where certain settings were stored. I will have to have a good look around. Is there a way to install a local package? I have built a cursor package in .pkg.tar.zst format as the aur version doesn't work (seems to have been abandoned a long time ago). Is there a way to build that into the iso or would I have to pacman -U it?
