I want to reset the fish welcome,just like the picture below,I like the dragon.
and now the fish is
I found that there is no neofetch package,how it works
garuda_inxi
✦ ╰─λ garuda-inxi
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=02dd6513-7248-4e33-ab4f-d040aa9390f4 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: Dell product: Inspiron 5585 v: 2.1.0
serial: <superuser required> Chassis: type: 10 v: 2.1.0
Mobo: Dell model: 09PR8G v: A00 serial: <superuser required> UEFI: Dell
v: 2.1.0 date: 04/12/2019
ID-1: BAT0 charge: 29.7 Wh (100.0%) condition: 29.7/42.0 Wh (70.8%)
volts: 12.9 min: 11.4 model: SMP-ATL-3.61 DELL VM73283 type: Li-poly
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1416 high: 1678 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1274 2: 1397
3: 1678 4: 1395 5: 1397 6: 1397 7: 1396 8: 1400 bogomips: 33537
Device-1: AMD Lexa [Radeon 540X/550X/630 / RX 640 E9171 MCM] vendor: Dell
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6987 class-ID: 0380
temp: 44.0 C
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Dell driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 54.0 C
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 0bda:5521 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0819 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon Vega 8 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.2.11-zen1-1-zen) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
IF-ID-1: br-ca2d2206547d state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: vethc7c17cc state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2.3:4
chip-ID: 0cf3:e009 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
Local Storage: total: 476.95 GiB used: 94.42 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC501 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 80002C00 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Tigo model: SSD 256GB size: 238.47 GiB
serial: <filter> rev: 155 scheme: GPT
used: 94.42 GiB (39.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 5.67 GiB used: 181.9 MiB (3.1%)
System Temperatures: cpu: 54.0 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2519
GPU: device: amdgpu temp: 54.0 C device: amdgpu temp: 44.0 C watts: 4.02
Processes: 324 Uptime: 6h 41m wakeups: 32 Memory: 5.68 GiB
used: 3.37 GiB (59.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1331
libs: 394 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-04-04
Last full system update: 2023-04-21 ↻
