I am a new Linux user, I just install Dragonized Gaming Edition version.
I make a mistake that l lost the orginal theme which has a dragon on the top.
I don't know how to reset it.
Hi,
I don't know exactly what you've touched, but I think you could first try resetting the configuration from Garuda Assistant (there is a button on the buttom for that.
If not working, imo you could rollback to a previous status recovering a snapshot (from the grub at first, and then confirming the restore in timeshift: make sure to use the same snapshots!)
There are 2 methods
Can I use command line to doing that?
Yes, copy etc/skel/.config to .config folder in your home directory using rm -r and then cp.
