Hi guys, I want to remove garuda-wallpaper package (sorry, wallpapers are really good, but I just prefer another style for my desktop).
When I try to remove it from the package manager, I have the following error
If you don't want the Garuda settings package then remove that one too - but also keep in mind that you won't get any updates to theming etc.
The alternative is just to set a different wallpaper.
Yeah, that's a problem - I want garuda-common-settings to stay
So, if you really want to remove the package - rather than just setting a different wallpaper - then you can force pacman to ignore the dependency with pacman -Rdd garuda-wallpaper
. I don't recommend breaking dependencies like this, but for wallpaper it probably doesn't matter.
Also just to note from your OP, pasting text output as text is generally a better option.
Right, images is not the best solution for reports, will keep it in mind
usr/share/wallpaper/garuda-wallpapers just delete the ones in the folder you don't want.
I agree.
Then hold the garuda-wallpaper
package so that it is never updated in the future.
That would seem preferable to removing it entirely IMO as it is a dependency of garuda-common-settings
