How To Remove Fish Shell & Just Use Bash
I would like to know how to change the konsole configuration. I have walked in the dark for quite sometime now, and going to lighter themes. Currently I find the konsole-fish (don’t yell at me just because I don’t know the exact name for this) theme hard on my eyes.
Looked at the web configuration for Fish, the results were far from satisfying.
What I’m looking for is not use fish, use a plain konsole. Is that possible?
Please always provide your garuda-inxi as required in the topic template.
Anyway, fish is the shell, the “language”, to interact with the system, so it’s not part of you graphical problem.
Konsole is your terminal emulator, the application that you use. So it manages the appearence.
For konsole, check Settings → Edit Current Profile → Appearence → Edit (e g. the current color scheme) and play around with it.
Didn’t post inxi, cause I didn’t this this was something warranting aan inxi. But rules are rules, my bad :face_with_symbols_over_mouth:
My Inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ca46cfb3-682f-4d27-ab75-37f70793ff5a rw rootflags=subvol=@
quiet resume=UUID=b8625a64-75a5-4b7a-9aeb-c6aef537fd04 loglevel=3
split_lock_detect=off sysrq_always_enabled=1 ibt=off
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: X515EA.309
date: 05/16/2022
ID-1: BAT0 charge: 21.3 Wh (59.0%) condition: 36.1/37.1 Wh (97.2%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 31
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 487 high: 1098 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1098 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 322e:2103
class-ID: 0e02
Monitor-1: eDP-1 res: 1670x939 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0032
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 66.03 GiB (7.1%)
fw-rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
used: 66.03 GiB (7.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-4: /var/log raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2300
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.85 GiB (25.1%)
Processes: 249 Power: uptime: 5h 42m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1514 libs: 402 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-01-25
Last full system update: 2024-02-14 ↻
I have modified config-fish:
## Run fastfetch if session is interactive
#if status --is-interactive && type -q fastfetch
#   fastfetch --load-config dr460nized
#end
And have changedit to Edna Light.
Done and am happier than a pig in sh**t
Doesn’t take much to make me happy.
Gotta like yer style. :smiley:
