Hi,
I tried to set up a convertible Laptop and I want to perform a right-click when holding a left-click for long enough. I installed “evdev-right-click-emulation” through the chaotic-AUR and it showed up in the Garuda Assitent under the Settings tab. I enabled all options under Right Click Emulation. After a reboot i used the command:
LONG_CLICK_INTERVAL=500 LONG_CLICK_FUZZ=50 evdev-rce
The output was:
Found touch screen at /dev/input/event17: ELAN0511:00 04F3:303F Touchpad
Found touch screen at /dev/input/event11: ELAN Touchscreen
Found touch screen at /dev/input/event10: ELAN Touchscreen Stylus
Instead of performing a right-click it entered Edit Mode when used on desktop and it would be nice if somebody could tell me how to deactivate this feature. It also did not work in any application.
SGS
13 September 2022 19:41
2
Welcome
Why don’t you post your garuda-inxi as required by the template?
Schnitzelklopfer:
Deinstall
I don't have a direct solution for you, but maybe you could pursue researching xinput and find something to help within. Posting xinput list results would be probably be good.
As SGS beat me to, always post your garuda-inxi
https://wiki.archlinux.org/title/Xinput
filo
13 September 2022 19:55
4
You could also try launching it with sudo, as suggested on upstream site.
If not working, maybe give a look at the issues there...
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=5a8ffac4-c0c6-4fe8-929f-d65ffe401e6b rw rootflags=subvol=@
Type: Convertible System: Acer product: Spin SP515-51N v: V1.07
Mobo: KBL model: Buzz_KL v: V1.07 serial: <superuser required>
UEFI: Insyde v: 1.07 date: 03/05/2018
ID-1: BAT0 charge: 42.5 Wh (96.8%) condition: 43.9/50.8 Wh (86.4%)
volts: 16.2 min: 15.3 model: SMP-SDI3320 AC14B7K type: Li-ion
Device-1: hid-0003:04F3:25A1.0003-battery model: ELAN Touchscreen
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3300 high: 3301 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3300 2: 3300 3: 3299
4: 3300 5: 3301 6: 3300 7: 3300 8: 3300 bogomips: 31999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 04f2:b5f7 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d7 built: 2015 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Sound Server-1: ALSA v: k5.19.7-zen2-1-zen running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-5:3
chip-ID: 04ca:3016 class-ID: e001
Local Storage: total: 238.47 GiB used: 85.9 GiB (36.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-1: / raw-size: 237.97 GiB size: 237.97 GiB (100.00%) used: 85.9 GiB
(36.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 237.97 GiB size: 237.97 GiB (100.00%) used: 85.9
GiB (36.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 237.97 GiB size: 237.97 GiB (100.00%) used: 85.9
ID-5: /var/tmp raw-size: 237.97 GiB size: 237.97 GiB (100.00%) used: 85.9
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 89.0 C pch: 70.0 C mobo: N/A
Processes: 279 Uptime: 3m wakeups: 4 Memory: 7.68 GiB used: 2.91 GiB
(37.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1894 lib: 536
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.20
Garuda (2.6.7-1):
System install date: 2022-09-06
Last full system update: 2022-09-13
Failed units: auto-cpufreq.service
I'm very sorry that I forgot to add garuda-inxi, it won't happen again.
Deinstalling evdev-right-click-emulation wont solve the problem that i enter edit mode because it is a feature that is preconfigured in KDE and evdev-right-click-emulation just does nothing at all. And I did not find an option to add a delay to the right-click if i perform a left-click.
Check Settings -> Hardware -> Input Devices -> Touchpad. I don't have a touchpad, so I can't see what may be there.
Try turning off any mouse-related (accessibility) effects in Settings -> Workspace Behavior -> Desktop Effects?
Try altering repeat interval within Settings -> Accessibility -> Mouse Navigation
I'm not sure where else would be feasible to find related settings, since I'm led to believe they're there by this: libinput - ArchWiki
system
Closed
28 September 2022 15:46
9
