Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/25/2022
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3670 high: 4170 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3378 2: 3369
3: 3805 4: 3895 5: 3594 6: 4170 7: 3692 8: 3627 9: 3744 10: 3557 11: 3593
12: 3617 bogomips: 86241
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Sapphire driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Asus MX239 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 528x310mm (20.79x12.2") diag: 612mm (24.1") ratio: 15:9 modes:
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-5:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.13 TiB used: 509.19 GiB (44.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41061C20 temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP240G4
type: SSD serial: <filter> rev: 0410 scheme: GPT
ID-1: / raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
used: 19.05 GiB (19.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-f67fb17e-b2e2-4b91-9070-bd9fecb58eb5
used: 720 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 103.32 GiB (46.2%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-1193a6aa-4ce9-483a-8bef-63caff32ae67
ID-4: /var/log raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.16 GiB size: 97.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.59 GiB used: 1.83 GiB (11.8%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1724
Processes: 397 Uptime: 3h 6m wakeups: 1 Memory: 15.6 GiB
used: 3.7 GiB (23.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1838 lib: 520 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-08
Last full system update: 2022-05-08
Hello,
Is there a way to make the top bar of dragonized edition always transparent? At the moment it turns black when a window is maximized. I would like to make it always transparent regardless of the window.
Jim
