Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=dce650f1-f4c4-417c-9d13-d1bbcca3e55e rw rootflags=subvol=@
nvidia-drm.modeset=1 rd.udev.log_priority=3 vt.global_cursor_default=0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4021
date: 08/09/2021
Device-1: ps-controller-battery-4c:b9:9b:94:01:9b model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4020 high: 4248 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3500
3: 4228 4: 3500 5: 4195 6: 4225 7: 4199 8: 4248 9: 4228 10: 4226 11: 4212
12: 4221 13: 4239 14: 3500 15: 3500 16: 4221 17: 4247 18: 3500 19: 4215
20: 4225 21: 4244 22: 3500 23: 3500 24: 3500 25: 4244 26: 4223 27: 4226
28: 4213 29: 4225 30: 4220 31: 4226 32: 4214 bogomips: 223997
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1 empty: DP-2, DP-3, HDMI-A-1,
HDMI-A-2 bus-ID: 09:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2 chip-ID: 046d:085e
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 5120x1440 s-dpi: 109 s-size: 1193x342mm (46.97x13.46")
s-diag: 1241mm (48.86")
Monitor-1: DP-1 mapped: DP-0 note: disabled model: Philips PHL 498P9Z
serial: <filter> built: 2022 res: 5120x1440 hz: 165 dpi: 130048 gamma: 1.2
size: 1x1mm (0.04x0.04") diag: 1238mm (48.7") modes: max: 3840x1080
min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
bus-ID: 09:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Nektar Impact GX49 driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 2467:2033
class-ID: 0103
Device-4: Yamaha Steinberg UR22C driver: snd-usb-audio type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.1:5 chip-ID: 0499:172f
class-ID: 0103
Device-5: Logitech BRIO Ultra HD Webcam
Device-6: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-3.2:8 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-3: Sony DualSense wireless controller (PS5)
Device-1: Realtek Bluetooth 5.1 Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0bda:8771
Local Storage: total: 10.92 TiB used: 753.56 GiB (6.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 49.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST6000DM003-2CY186
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 1TB
ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT1000MX500SSD4
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 753.56 GiB (40.5%)
used: 753.56 GiB (40.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: 36.0 C gpu: nvidia temp: 45 C
Processes: 525 Uptime: 4h 13m wakeups: 2 Memory: total: 128 GiB note: est.
available: 125.71 GiB used: 7.49 GiB (6.0%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 12
clang: 15.0.7 Packages: 1864 pm: pacman pkgs: 1859 libs: 511
tools: octopi,paru,yay pm: flatpak pkgs: 5 Shell: fish v: 3.6.1
running-in: konsole inxi: 3.3.28
System install date: 2023-07-07
Last full system update: 2023-07-15 ↻
So I've noticed that fonts do not commit on applications like Firefox/Librewolf, Thunderbird, etc which I assume at GTK3/4 applications.
I've double-checked the GNOME/GTK Application Style in KDE Application Style which is set to "Sweet Dark".
All of my fonts are set in the KDE fonts section and I'm using "Overpass" as my font.
My .gtkrc-2.0 is:
gtk-enable-animations=1
gtk-primary-button-warps-slider=1
# DO NOT EDIT! This file will be overwritten by LXAppearance.
# Any customization should be done in ~/.gtkrc-2.0.mine instead.
gtk-theme-name="Sweet-Dark"
gtk-icon-theme-name="BeautyLine"
gtk-font-name="Overpass, Demi Bold 10"
gtk-cursor-theme-name="Sweet-cursors"
gtk-cursor-theme-size=24
gtk-toolbar-style=3
gtk-toolbar-icon-size=GTK_ICON_SIZE_LARGE_TOOLBAR
gtk-button-images=1
gtk-menu-images=1
gtk-enable-event-sounds=1
gtk-enable-input-feedback-sounds=1
gtk-xft-antialias=1
gtk-xft-hinting=1
gtk-xft-hintstyle="hintslight"
gtk-xft-rgba="rgb"
gtk-modules="colorreload-gtk-module:window-decorations-gtk-module"
My .config/gtk-4.0/settings.ini is as follows:
[Settings]
gtk-application-prefer-dark-theme=true
gtk-cursor-theme-name=Sweet-cursors
gtk-decoration-layout=close,maximize,minimize:
gtk-enable-animations=true
gtk-font-name=Overpass, Demi Bold 10
gtk-icon-theme-name=BeautyLine
gtk-primary-button-warps-slider=true
gtk-theme-name=Sweet-Dark
gtk-xft-dpi=98304
and my ~/.config/gtk-3.0/settings.ini file is:
[Settings]
gtk-button-images=true
gtk-menu-images=true
gtk-modules=colorreload-gtk-module:window-decorations-gtk-module
gtk-toolbar-style=3
gtk-xft-antialias=1
gtk-xft-dpi=98304
gtk-xft-hinting=1
gtk-xft-hintstyle=hintslight
gtk-xft-rgba=rgb
I read through the arch wiki and through here and nothing resolves the problem, even trying to play around with fonts.conf didn't do anything. So I installed lxappearance just to check and this is what appears everytime I reboot the system.
The default font is set to "None". If I change it in LXAppearance it changes the font correctly till I reboot. Any ideas?
