Hi,
how to switch from the default Kernel:
Kernel: 6.4.12-zen1-1-zen
To a zen4 optimized kernel.
trying to use yay to install
3 aur/linux-amd 6.5.v.0-1 [+30 ~1.04]
Linux kernel aimed at the ZNVER4/MZEN4 AMD Ryzen CPU based hardware
results in a mkpicio not found message and nothing changes.
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=34f9d729-98ef-496b-83af-483eba5939e5 rw rootflags=subvol=@
quiet rd.luks.uuid=498813a1-787e-41b6-85fb-9d7b318df474 quiet
iomem=relaxed amd_iommu=on iommu=pt# Modified by garuda-migrations:
splash ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: GPD product: G1619-04 v: Ver.1.0 serial: <filter>
Mobo: GPD model: G1619-04 v: Ver.1.0 serial: <filter> UEFI: American
Megatrends LLC. v: 0.29 date: 07/06/2023
ID-1: BAT0 charge: 59.2 Wh (87.3%) condition: 67.8/67.1 Wh (100.9%)
volts: 16.5 min: 15.4 model: Standard SR Real Battery type: Li-ion
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
Info: model: AMD Ryzen 7 7840U w/ Radeon 780M Graphics socket: FP8 bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
microcode: 0xA704103
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1706 high: 3300 min/max: 1600/6677 boost: enabled
base/boost: 3300/5125 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1600 2: 1600 3: 1600 4: 1600
5: 1600 6: 1600 7: 1600 8: 1600 9: 3300 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 105394
Device-1: AMD Phoenix1 vendor: IP3 Tech driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 64:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 36.0 C
Device-2: Tripath USB Camera driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.1:3 chip-ID: 058e:3864
class-ID: 0e02
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: eDP-1 mapped: eDP model: GPD1001H serial: <filter> built: 2022
res: 1680x1050 hz: 60 dpi: 197 gamma: 1.2 size: 217x135mm (8.54x5.31")
diag: 1021mm (40.2") ratio: 16:9 modes: max: 2560x1600 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon Graphics (gfx1103_r1
LLVM 15.0.7 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.1
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.78 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 3.64 TiB used: 902.21 GiB (24.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT4000P3PSSD8
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 35.9 C
SMART: yes health: PASSED on: 30 hrs cycles: 48
read-units: 3,930,786 [2.01 TB] written-units: 3,625,612 [1.85 TB]
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 902.21 GiB (24.2%)
fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-498813a1-787e-41b6-85fb-9d7b318df474
used: 720 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 902.21 GiB (24.2%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-498813a1-787e-41b6-85fb-9d7b318df474
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-1: swap-1 type: zram size: 54.65 GiB used: 25.8 MiB (0.0%)
System Temperatures: cpu: 40.9 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 369 Uptime: 28m wakeups: 17329 Memory: total: 56 GiB note: est.
available: 54.65 GiB used: 4.25 GiB (7.8%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1540 libs: 388 tools: octopi,pamac,paru
inxi: 3.3.29
System install date: 2023-08-08
Last full system update: 2023-08-29
