How to increase driver timeout in amdgpu driver?
Inxi
Kernel: 6.4.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=159c3fcc-1979-42ad-b091-265351522836 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland dm: SDDM
Type: Server System: Supermicro product: M12SWA-TF v: 123456789
serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
Mobo: Supermicro model: M12SWA-TF v: 1.01 serial: <filter> UEFI: American
Megatrends LLC. v: 2.0a date: 03/18/2022
Info: model: AMD Ryzen Threadripper PRO 5975WX s socket: SP3 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
process: TSMC n7 (7nm) family: 0x19 (25) model-id: 8 stepping: 2
microcode: 0xA008204
Topology: cpus: 1x cores: 32 tpc: 2 threads: 64 smt: enabled cache:
L1: 2 MiB desc: d-32x32 KiB; i-32x32 KiB L2: 16 MiB desc: 32x512 KiB
L3: 128 MiB desc: 4x32 MiB
Speed (MHz): avg: 1982 high: 3600 min/max: 1800/7007 boost: enabled
base/boost: 3600/4550 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 1800 3: 1800 4: 1800
5: 1800 6: 1800 7: 1800 8: 1800 9: 1800 10: 1800 11: 1800 12: 1800
13: 1800 14: 1800 15: 1800 16: 1800 17: 1800 18: 1800 19: 3600 20: 1800
21: 1800 22: 1800 23: 1800 24: 1800 25: 1800 26: 1800 27: 1800 28: 3600
29: 2700 30: 1800 31: 1800 32: 1800 33: 1800 34: 3600 35: 1800 36: 1800
37: 1800 38: 1800 39: 1800 40: 1800 41: 1800 42: 1800 43: 1800 44: 1800
45: 1800 46: 1800 47: 1800 48: 1800 49: 1800 50: 1800 51: 1800 52: 1800
53: 3600 54: 1800 55: 1800 56: 1800 57: 1800 58: 1800 59: 1800 60: 1800
61: 1800 62: 1800 63: 1800 64: 3600 bogomips: 459923
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire NITRO+
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 empty: none bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: ASPEED Graphics Family driver: ast v: kernel ports: active: none
off: DVI-I-1 empty: none bus-ID: 68:00.0 chip-ID: 1a03:2000 class-ID: 0300
Display: server: X.Org v: 23.1.2 with: Xwayland v: 23.1.2
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu,ast
display-ID: :1 screens: 1
Screen-1: 0 s-res: 8720x2560 s-dpi: 96 s-size: 2307x677mm (90.83x26.65")
s-diag: 2404mm (94.66")
Monitor-1: DP-1 pos: primary,2-2 res: 3440x1440 hz: 165 dpi: 109
size: 800x340mm (31.5x13.39") diag: 869mm (34.22") modes: N/A
Monitor-2: DP-2 pos: 2-4 res: 1920x1080 hz: 60 dpi: 30
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
Monitor-3: HDMI-A-1 pos: 1-3 res: 1440x2560 hz: 120 dpi: 108
size: 340x600mm (13.39x23.62") diag: 690mm (27.15") modes: N/A
Monitor-4: HDMI-A-2 pos: 2-1 res: 1920x1080 hz: 120 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 7900 XTX (gfx1100
LLVM 15.0.7 DRM 3.52 6.4.7-zen1-2-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 22:00.4 chip-ID: 1022:1487
Device-3: SAVITECH SA9023 audio controller
lanes: 1 mode: 1.1 bus-ID: 1-4.1:4 chip-ID: 262a:9023 class-ID: 0102
Device-4: Trust B.V. USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 15d9:1c1c class-ID: 0300
Device-5: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 9-2.1:5 chip-ID: b58e:9e84 class-ID: 0300
API: ALSA v: k6.4.7-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: n/a (root, process) with:
Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 66:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Super Micro driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 69:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 59.0 C
IF: eth2 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-1: enp34s0f3u2u2c2 state: unknown speed: -1 duplex: half
mac: <filter>
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Insyde RNDIS/Ethernet Gadget driver: rndis_host v: kernel
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-2.2:4
chip-ID: 0b1f:03ee class-ID: 0a00
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 1.75 TiB used: 689.24 GiB (38.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPE21D960GA
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: E2010603 temp: 36.9 C
SMART: yes health: PASSED on: 191d 15h cycles: 480
read-units: 45,021,357 [23.0 TB] written-units: 37,940,482 [19.4 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Intel model: SSDPE21D960GA
lanes: 4 tech: SSD serial: <filter> fw-rev: E2010603 temp: 34.9 C
SMART: yes health: PASSED on: 189d 0h cycles: 429
read-units: 200,799,888 [102 TB] written-units: 88,084,175 [45.0 TB]
ID-1: / raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
used: 220.05 GiB (24.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:7
used: 580 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
ID-3: /home raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 893.96 GiB size: 893.96 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 125.63 GiB used: 184.2 MiB (0.1%)
System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 65.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 569
Processes: 861 Uptime: 19m wakeups: 0 Memory: total: 128 GiB
available: 125.63 GiB used: 8.74 GiB (7.0%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1955 libs: 554 tools: octopi,paru
inxi: 3.3.28
System install date:     2023-07-29
Last full system update: 2023-08-02
Windows dual boot:       Yes
Running a Sapphire Nitro 7900XTX (in secondary vbios setting) and been having issues with driver timeouts in both linux and windows. They're a bit more violent in linux since they tend to break the entire desktop session and force me to drop into tty to kill the session. These only happen when playing certain games, and aren't always super consistent.
Long story short, changing TDR in windows to 10 seemed to have largely remedied a lot of the issues, but i can't for the life of me find out how to do the same on garuda for AMD, the only stuff i'm finding is for nvidia cards. Anybody happen to know how? Would appreciate it, thanks.
I don't have an idea if this makes sense at all :blush: but try to give a look at lockup_timeout here:
https://kernel.org/doc/html/latest/gpu/amdgpu/module-parameters.html
Interesting, so if i'm interpreting that right, the default is already 10 seconds then? (10000ms)
Man this card has been such a pain. And it seems like i'm not alone on that front either through the ridiculous amount of research i've had to do on the topic. Considering going back to my 3080ti despite hating the experience it provides on linux.
