So i searched a lot but i coudnt find any answers to make this happen
so basically i want to get my speaker output as input in my system for some reasons and im unable to find a solution for this. requesting your help
Kernel: 6.4.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=59ff8f57-40eb-44e8-a015-2dc55332762b rw rootflags=subvol=@
resume=UUID=8742d7a9-dccf-4336-ab40-4d80134b6d69 loglevel=3 ibt=off
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706IC_FA706IC
Mobo: ASUSTeK model: FA706IC v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706IC.302 date: 12/28/2022
ID-1: BAT1 charge: 62.0 Wh (85.2%) condition: 72.8/90.2 Wh (80.7%)
volts: 16.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1786 high: 2900 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1397
3: 2900 4: 1400 5: 1400 6: 1400 7: 2900 8: 1400 9: 1400 10: 2900 11: 1568
12: 1400 13: 1422 14: 2900 15: 1400 16: 1397 bogomips: 92630
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 43.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a11 built: 2021
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
missing.
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.4.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 1.38 TiB used: 254.64 GiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 36.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLQ512HBLU-00BTW size: 476.94 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 25.9 C scheme: GPT
ID-1: / raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
used: 254.64 GiB (27.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
ID-4: /var/log raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.66 GiB size: 914.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 0
Processes: 407 Uptime: 3h 17m wakeups: 5 Memory: total: 16 GiB note: est.
available: 15.05 GiB used: 8.39 GiB (55.8%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: 1506
pm: nix-default pkgs: 48 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
pkgs: 1449 libs: 384 tools: pamac,paru,yay pm: flatpak pkgs: 9 Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
System install date: 2023-06-01
Last full system update: 2023-07-28
