Hello! I'm trying to figure out how to use the default Gnome gestures that ships with Gnome by default. Would I just comment out the config file for libinput-gestures? Or should I remove libinput-gestures altogether? How would I have the system look to use the Gnome gestures by default?
I have nothing against the gestures that have been set up, but to me personally I just think the default Gnome gestures are more fluid and natural to me.
Result of sudo garuda-inxi:
Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=582fe4f2-5018-4d18-8d04-795dc063e031 rw rootflags=subvol=@
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PM_FX516PM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX516PM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FX516PM.322 date: 08/27/2021
ID-1: BAT0 charge: 66.5 Wh (100.0%) condition: 66.5/76.0 Wh (87.6%)
status: not charging cycles: 75
Info: model: 11th Gen Intel Core i7-11370H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2344 high: 3300 min/max: 400/4800 base/boost: 3300/4800
ext-clock: 100 MHz cores: 1: 756 2: 400 3: 3300 4: 3300 5: 1100 6: 3300
7: 3300 8: 3300 bogomips: 52838
Message: PCI device data requires root.
Display: server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: N/A display-ID: :0
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
missing.
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
IF-ID-2: eno2 state: down mac: <filter>
IF-ID-3: wlo1 state: up mac: <filter>
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 17.89 GiB (3.8%)
rev: FXM7201Q temp: 39.9 C scheme: GPT
ID-1: / raw-size: 101.38 GiB size: 101.38 GiB (100.00%)
used: 17.89 GiB (17.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: /boot/efi raw-size: 1.16 GiB size: 1.16 GiB (99.80%)
used: 608 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /home raw-size: 101.38 GiB size: 101.38 GiB (100.00%)
maj-min: 259:6
ID-4: /var/log raw-size: 101.38 GiB size: 101.38 GiB (100.00%)
maj-min: 259:6
ID-5: /var/tmp raw-size: 101.38 GiB size: 101.38 GiB (100.00%)
maj-min: 259:6
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 298 Uptime: 6m wakeups: 425 Memory: 15.32 GiB used: 3 GiB (19.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1400 libs: 362
tools: gnome-software,pamac,paru pm: flatpak pkgs: 0
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-05
Last full system update: 2022-12-05
Windows dual boot: Yes
