Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b13a369-b041-4975-8b36-e67239723d2c rw [email protected]
Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.33
Mobo: CFL model: Octavia_CFS v: V1.33 serial: <superuser required>
UEFI: Insyde v: 1.33 date: 11/17/2020
ID-1: BAT1 charge: 41.3 Wh (100.0%) condition: 41.3/58.8 Wh (70.2%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: Full
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 866 high: 1108 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1108 2: 851 3: 872
4: 854 5: 800 6: 803 7: 802 8: 876 9: 900 10: 900 11: 801 12: 835
bogomips: 62399
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting,nvidia
Screen-1: 0 s-res: 1920x1848 s-dpi: 96 s-size: 506x487mm (19.9x19.2")
s-diag: 702mm (27.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Monitor-2: HDMI-1-0 res: 1366x768 hz: 60 dpi: 85
size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br-d4230d5827ef state: down mac: <filter>
IF-ID-3: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 43.69 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD4
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 442.94 GiB size: 442.94 GiB (100.00%)
used: 15.48 GiB (3.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
ID-3: /home raw-size: 442.94 GiB size: 442.94 GiB (100.00%)
ID-4: /var/log raw-size: 442.94 GiB size: 442.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.94 GiB size: 442.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C pch: 62.0 C mobo: N/A
Processes: 332 Uptime: 50m wakeups: 1 Memory: 31.19 GiB
used: 3.33 GiB (10.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1256 lib: 314 Shell: Zsh v: 5.8
running-in: alacritty inxi: 3.3.11
My conky setup is showing empty boxes around time and date. I tried changing font in ~/.config/conky/conky.conf
but it did not fix. I changed the font to source code pro
from sans mono
