How to extend laptop battery life
HI, if i want to have the best battery life do i just disable the perfomance tweaks and enable the power save ones or what do i do
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d9add5f7-e174-4a38-a597-8a58b5ca51ea rw rootflags=subvol=@
resume=UUID=b450e3fb-e2f9-478a-a17c-b051f23fa5e9 loglevel=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: Micro-Star product: GF65 Thin 10UE v: REV:1.0
Mobo: Micro-Star model: MS-16W2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16W2IMS.105 date: 05/14/2021
ID-1: BAT1 charge: 47.3 Wh (98.7%) condition: 47.9/51.3 Wh (93.4%)
volts: 12.8 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i5-10500H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3754 high: 4298 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4261 2: 4291 3: 4298
4: 4200 5: 3466 6: 4278 7: 4260 8: 2500 9: 4220 10: 1809 11: 3175 12: 4290
bogomips: 59998
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.2 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 200.67 GiB (42.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 35.9 C scheme: GPT
used: 200.67 GiB (42.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.58 GiB used: 1.9 GiB (25.0%) priority: 100
System Temperatures: cpu: 63.0 C pch: 51.0 C mobo: N/A
Processes: 314 Uptime: 7h 38m wakeups: 1 Memory: 7.58 GiB
used: 5.29 GiB (69.8%) Init: systemd v: 251 default: graphical
pkgs: 2038 libs: 563 tools: octopi,paru,yay Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date:     2022-10-09
Last full system update: 2022-11-09
Yes :slight_smile:
You can also manually set low CPU frequency speeds and disable keyboard backlight if you have support for that.
In KDE plasma there is a good plasmoid app for this that sits in the taskbar. Find it in chaotic-aur as 'plasma5-applets-plasma-pstate', love this one. :heart_hands:
