Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature) - Format terminal output (including your
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Here is garuda-inxi for my system:
Kernel: 6.6.29-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b99392d7-da0f-4aac-b8e6-4b9bc075f4d2 rw rootflags=subvol=@
quiet resume=UUID=222f780c-a799-446c-adfa-addfc68f177d loglevel=3 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: Inspiron 15-5568 v: N/A
Mobo: Dell model: 00T7MP v: A00 serial: <superuser required> part-nu: 073D
uuid: <superuser required> UEFI-[Legacy]: Dell v: 1.23.0 date: 01/19/2021
ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/42.0 Wh (88.1%)
volts: 12.6 min: 11.4 model: SMP DELL 3CRH35B type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse M325
Info: model: Intel Core i3-6100U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 400 min/max: 400/2300 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 18406
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:7
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:576d
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0x10ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 24.1.5-arch1.1
device-ID: 8086:1916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.1 (LLVM
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.6.29-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0a2a
Local Storage: total: 465.76 GiB used: 10.59 GiB (2.3%)
model: WD5000LPCX-75VHAT0 size: 465.76 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 457.9 GiB size: 457.9 GiB (100.00%) used: 10.59 GiB (2.3%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 457.9 GiB size: 457.9 GiB (100.00%)
used: 10.59 GiB (2.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 457.9 GiB size: 457.9 GiB (100.00%)
ID-4: /var/tmp raw-size: 457.9 GiB size: 457.9 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.57 GiB used: 1.93 GiB (53.9%)
ID-2: swap-2 type: partition size: 7.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 49.0 C pch: 46.0 C mobo: 45.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Memory: total: 4 GiB note: est. available: 3.57 GiB used: 2.58 GiB (72.3%)
Processes: 264 Power: uptime: 2h 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.42 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1256 libs: 399 tools: paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.35
System install date: 2024-08-03
Last full system update: 2024-08-03 ↻
Am trying to get both my built-in webcam and an external webcam working but not finding a solution. Please advise. Thanks!
