How to disable hibernation?
I tried in many ways, here are some examples:
  1. xset s -noblank
  2. /etc/systemd/[sleep/logind].conf (I set everything related to hibernation to no/ignore, I also tried changing the time - it seems like the monitor goes out, but allows you to turn on if it was in sleep mode for no more than ~10 minutes)
I don’t really understand what’s wrong. I can’t exit this mode, although if I press Ctrl+Alt+F3, log in, enter “Hyprland”, the session will restart (although the old login remains hanging as dead weight)
Screenshot (I’m not sure if this is hibernation, I didn’t quite understand how to get system logs in this case): Screenshot-20250615-200435-Google hosted at ImgBB — ImgBB
Thanks in advance.
Where’s the garuda-inxi? We have very little info to go on here.
Maybe this will help: https://medium.com/@mynameised/hypridle-wont-wake-up-from-sleep-hyprland-4db25fe9af08
Well, without garuda-inxi no one can say anything ,
but you can take a look here :
https://gitlab.com/garuda-linux/themes-and-settings/settings/garuda-hyprland-settings/-/blob/main/etc/skel/.config/hypr/hypridle.conf?ref_type=heads
Thank you, after setting up the hypridlе stopped turning off
Thank you! It seemed to work, I left the PC overnight - in the morning it still hadn’t turned off
I’ll learn to use logs, last time I debugged Termux :р
We always mark here the solution and not the implementation.
:slight_smile:
