How to disable compositor on garuda dragonized
Hey, after trying out garuda hyprland (which by the way i think was a total waste of ressources) i downloaded the latest dragonized iso and installed it. the problem now is that i am unable to disable the compositor, not with shift alt f12, nor in the settings, nor with telling kwin to suspend the module. Did someone once again move settings around or is the compositor now forced in the latest iso? And yes on my laptop that got an garuda dragonized install from mid 2022 the option is right where i think it should be, the very same settings window on my desktop pc does not show these options anymore
inxi for whatever
    root=UUID=372689e5-8a05-4c8d-b0a1-d5cb4d6fc475 rw rootflags=subvol=@
    quiet rd.luks.uuid=bdc9d9a7-5505-4937-ac5a-6b24c7ab837d
    rd.luks.uuid=6c89d81b-0faf-4455-a69c-ed567e9a4272
    resume=/dev/mapper/luks-6c89d81b-0faf-4455-a69c-ed567e9a4272 loglevel=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: M.J0
    date: 06/30/2023
  Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
    family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 632 high: 3188 min/max: 400/4267 scaling:
    4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 3188 11: 400 12: 400
    bogomips: 86231
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
    active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 12:00.0 chip-ID: 1002:73ff
    gpu: amdgpu d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
    drv: radeonsi inactive: gbm
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
    16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:ab28
  Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
  Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
  Device-4: JMTek LLC. USB PnP Audio Device
    lanes: 1 mode: 1.1 bus-ID: 3-2.2:4 chip-ID: 0c76:161e class-ID: 0300
  Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
    lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 4.21 TiB used: 193.06 GiB (4.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 24.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LX005-1CW162
    tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD1 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
    tech: SSD serial: <filter> fw-rev: 054
  ID-5: /dev/sde maj-min: 8:64 vendor: SanDisk model: USB 3.2Gen1
    size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
    used: 9.99 GiB (1.1%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-bdc9d9a7-5505-4937-ac5a-6b24c7ab837d
  ID-3: /home raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
  ID-4: /var/log raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.86 GiB size: 896.86 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
    mapped: luks-6c89d81b-0faf-4455-a69c-ed567e9a4272
  ID-2: swap-2 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 32.6 C mobo: N/A gpu: amdgpu temp: 29.0 C
    mem: 30.0 C
  Processes: 333 Uptime: 1h 28m wakeups: 0 Memory: total: 32 GiB
  available: 31.23 GiB used: 3.59 GiB (11.5%) Init: systemd v: 254
  pm: pacman pkgs: 1280 libs: 388 tools: octopi,paru pm: flatpak pkgs: 0
  Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
  System install date:     2023-11-03
  Last full system update: 2023-11-03 ↻
The whatever here is to let us know you’re using Wayland.
I am under the impression you can not turn off the compositor under Wayland right now, maybe never.
If you really need to turn it off, you’ll probably need to switch to X11.
HTH :v:
how do i switch to that? i installed xorg and rebooted but i still can’t see an x11 option at the login screen, do i need to do something else?
The ‘swish’ says you need to reboot since your last update. Many times KDE settings will not take effect unless rebooted. Not always, but many times.
Please see what, if anything, a reboot yields.
I am afraid I don’t know this one. Might be SDDM’s configs don’t get overwritten.
This may help:
https://wiki.archlinux.org/title/SDDM
i did, it did not change anything, what worked for me is using an older garuda iso, tho i think that’s pretty sad…
