How to Disable auto no border?
I'm using Garuda Linux KDE and I have removed Latte-Dock as I do not like it, but the problem with this is that once I maximize a window (not fullscreen), the minimize, maximize, and close buttons do not appear. I've tried pressing alt + f3 to bring up the menu and unchecking the 'no border' button, but it doesn't disable it and it stays checked. Thanks in advance.
Ok. This should work:
micro .config/kwinrc
Then change
BorderlessMaximizedWindows=true
To
BorderlessMaximizedWindows=false
Then log out and back in.
Welcome to the forums!
