How to disable auto login?
Hi! Thanks for the work on Garuda, it's been awesome so far.
So, I can't find where to disable auto login for a user.
This should be present in the garuda user management, since it was toggled at installation, in my opinion.
I'm on XFCE, in case it matters.
Thank you!
https://duckduckgo.com/?t=ffnt&q=arch+linux+How+to+disable+auto+login%3F&ia=web
Simple search on your favorite search engine may have easily answered your question, but still, I have to solve this issue.
So, edit /etc/lightdm/lightdm.conf and remove line with auto-login for the user you want.
