Hello.
When I hold the "ALT" key, there will be a white line under some letters of each options in the menu bar.
I know it can be really helpful when navigating menu's options but sometimes it conficts with other software's keymap, so is there any way to turn it off? Thanks in advance.
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=95dc98c4-2ec4-4fc4-bbaa-642a90082b50 rw [email protected]
Type: Desktop Mobo: Micro-Star model: MEG B550 UNIFY-X (MS-7D13) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.40
date: 12/17/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3605 high: 3806 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3625 2: 3595
3: 3589 4: 3594 5: 3597 6: 3594 7: 3591 8: 3598 9: 3597 10: 3599 11: 3597
12: 3591 13: 3593 14: 3595 15: 3599 16: 3599 17: 3593 18: 3598 19: 3596
20: 3598 21: 3599 22: 3599 23: 3598 24: 3806 bogomips: 177602
STIBP: always-on, RSB filling
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2d:00.0 chip-ID: 1002:73ff
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 5280x2560 s-dpi: 96 s-size: 1395x676mm (54.9x26.6")
s-diag: 1550mm (61")
Monitor-1: DisplayPort-1 mapped: DP-2 pos: primary,right
model: LG (GoldStar) HDR 4K serial: <filter> built: 2021 res: 3840x2160
hz: 60 dpi: 140 gamma: 1.2 size: 697x392mm (27.4x15.4")
diag: 806mm (31.7") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-0 mapped: HDMI-A-1 pos: primary,left
model: Dell S2721DGF serial: <filter> built: 2021 res: 1440x2560 dpi: 109
gamma: 1.2 size: 336x597mm (13.2x23.5") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
OpenGL: renderer: AMD Radeon RX 6600 XT (DIMGREY_CAVEFISH DRM 3.44.0
5.16.16-zen1-1-zen LLVM 13.0.1)
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
Local Storage: total: 4.34 TiB used: 35.54 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: T-FORCE TM8FP7001T
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: EGFM13.0
temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Smart Modular Tech.
model: SHGP31-2000GM size: 1.82 TiB block-size: physical: 512 B
rev: 31060C20 temp: 38.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:5 vendor: SanDisk
model: Extreme Pro 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 101200RL temp: 36.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: BB.3 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 043 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 28.84 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 710.61 GiB size: 710.61 GiB (100.00%)
used: 35.45 GiB (5.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 901 MiB size: 897 MiB (99.56%)
used: 92 MiB (10.3%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 710.61 GiB size: 710.61 GiB (100.00%)
ID-4: /var/log raw-size: 710.61 GiB size: 710.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 710.61 GiB size: 710.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.33 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
mem: 52.0 C
Processes: 493 Uptime: 4h 21m wakeups: 0 Memory: 31.33 GiB
used: 9.65 GiB (30.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1472 lib: 427 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-15
Last full system update: 2022-03-24 ↻
