i have tried every possible way avilable on internet.
i stuck till more than 7 hours. i have to finish my project , please help asap
If you want to create a Windows USB from a Linux your best bets are woeusb or ventoy.
You can't use normal Linux imaging tools.
i tried woeusb though kernal , it shows like - you manually have to mount or unmount something..
now i am installing woeusb-gui
Can’t be. ![]()
Start reading next time
That is fixed in the upcoming version of woeusb.
For now, just make this change manually to your local files:
how can i do that
Edit /usr/bin/woeusb with a text editor and make the change I linked above.
1234567890
This is a detailed as I am getting.
If you look at around line 1050 of that file, you need to change:
-1024s \
to:
-2048s \
This is still a Garuda forum and should remain so.
We are not here to do your homework especially not ASAP.
We don't do free training here either.
Take Ventoy, done.
