How to configure Dualsense Controller
Hey all, trying to configure controllers for games yet whenever i plug in either a dualsense or a generic xinput controller neither detects, I have all the xbox options from Garuda Gamer, still no luck. Even plugging one in upon booting my system they still are not detected. When I go to my settings and check my input devices, theres an error “No joystick device automatically found on this computer.
Checks were done in /dev/js[0-4] and /dev/input/js[0-4]
If you know that there is one attached, please enter the correct device file”
root=UUID=f786acd2-1ba6-4cb5-9a52-e19fcc5fbf11 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG X570S TOMAHAWK MAX WIFI (MS-7D54)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.00
date: 07/06/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3725 high: 4121 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3598
3: 3800 4: 3596 5: 3604 6: 3800 7: 4121 8: 3800 9: 3881 10: 3600 11: 3800
12: 3800 13: 3624 14: 3600 15: 3595 16: 3592 bogomips: 121602
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:2482 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-2 pos: primary,left res: 1920x1080 dpi: 70
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 545.29.02 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2725
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0032
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 4.78 TiB used: 683.58 GiB (14.0%)
fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: MBR
used: 145.67 GiB (31.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 40.2 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 374 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.22 GiB (10.3%) Init: systemd v: 254
pm: pacman pkgs: 1833 libs: 543 tools: octopi,paru pm: flatpak pkgs: 0
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-13
Last full system update: 2023-12-01
Dualsense is PS5 correct? Output of
ls /dev/input/js
and
lsusb
From the wiki here try loading the modules with
modprobe usbhid
modprobe joydev
