the built in app "Keyboard and mouse" doesn't affect anything:
in archwiki i don't have any file named 50-mouse-accelaration.conf. i have 00-keyboard and 30-touchpad. and archwiki is scary i don't have guts to create a new conf file. i am confused which method to use or how to proceed. i found a file in .config'/autostart with this line
xset m 100/10 100 r rate 500 30 b on
in windows there is a thing, if you move mouse faster your cursor will go more distance than if you move it slower, which i want to be disabled.
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=5a1a7018-04d3-413c-8c48-65d37ccf7308 rw rootflags=subvol=@
resume=UUID=4d1231c9-2dd3-48e1-9758-f32fd70cbe97 loglevel=3
Desktop: Qtile v: 0.21.1.dev91+g5e54027e vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50
date: 11/27/2019
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3606 high: 3694 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3694
3: 3600 4: 3592 5: 3566 6: 3600 7: 3600 8: 3600 bogomips: 57491
protection
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositors: 1: Qtile
v: 0.21.1.dev91+g5e54027e 2: Picom v: git-affe4 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: LG (GoldStar) FULL HD
serial: <filter> built: 2020 res: 1920x1080 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 14.0.6 DRM
3.47 5.19.2-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
vendor: Sapphire driver: snd_hda_intel bus-ID: 3-1:2 v: kernel
chip-ID: 0c76:16cb pcie: class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-4.1:3 chip-ID: 0a12:0001 class-ID: e001
address: N/A
Local Storage: total: 1.14 TiB used: 53.42 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000PNP
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s34
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-1: / raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 53.4 GiB
(24.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.9 MiB
(8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 53.4
GiB (24.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 53.4
ID-5: /var/tmp raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 53.4
ID-1: swap-1 type: zram size: 15.57 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 55.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 801
Processes: 303 Uptime: 28m wakeups: 0 Memory: 15.57 GiB used: 2.91 GiB
(18.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: note: see --pkg pacman: 1658
lib: 481 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-04
Last full system update: 2022-08-20
Failed units: swapfile.swap
