How to add .png/.jpg/.svg icons to waybar
I had been looking around how to add the dragon icon in dr460nized as my nwg-drawer’s launcher. A lot of looking around told me waybar doesn’t have an explicit option to do this but you can still use the style.css file to get around this. I tried a bunch of available .css online but nothing worked. Except this,
I looked at this person’s comment to achieve my goal. This was just a lot of looking around so I posted it here in case someone else wants to do it they don’t need to be needlessly frustrated.
Just remember to use the absolute path to the image like /home/user/foo/bar/image.jpg and not something like ~/foo/bar/image.png, ~ is understood by shell not by anything else.
For the sake of completeness,
~/.config/waybar/config
"custom/launcher": {
        //"format":"<U+F44E>",
        "format":"    ",
        "tooltip": false,
        "on-click": "exec nwg-drawer -c 7 -is 70 -spacing 23",
The spaces are necessary they determine the width your icon is allowed to take we are setting it as this empty text’s background.
~/.config/waybar/style.css
#custom-launcher{
        font-size: 20px;
        background-image: url('/home/siddharth/.config/waybar/dr460nized-start.png');
        background-position: center;
        background-repeat: no-repeat;
        background-size: contain;
SGS’s dragon logo → https://gitlab.com/uploads/-/system/project/avatar/23323742/dr460nized-start.png
The image has no background which makes this more easy. Thankyou SGS. You saved me the pain of looking around for css to remove background afterwords. :rofl:
On another note,
bind = ,122, exec, pamixer --decrease 5; notify-send "<U+F1120> Volume: "$(pamixer --get-volume) -t 500
bind = ,123, exec, pamixer --increase 5; notify-send "<U+F1120> Volume: "$(pamixer --get-volume) -t 500
bind = ,121, exec, pamixer --toggle-mute; notify-send "<U+F0581> Volume: Toggle-mute" -t 500
bind = ,XF86AudioMicMute, exec, pactl set-source-mute @DEFAULT_SOURCE@ toggle; notify-send "System Mic: Toggle-mute" -t 500
I would like to suggest keybinding volume inc/dec. keys to pamixer instead of pactl. The reason is simple pactl just doesn’t stop at 100% it keeps going to infinity and beyond. A very stupid way of accidentally ruining your speakers according to me.
I left mic mute/unmute to pactl because it does this job better than pamixer.
Edit: apologies sgs I have fixed the comment, :slightly_smiling_face:
Great, I had already searched for it and found my Hamburg icon to be the best. :smiley:
Nico does a lot, a lot, actually too much :slight_smile:
but he doesn’t make any icons. But I made this for Nico :blush:
We take care of the health of our users, so let’s keep it that way.
Everyone can change it as they like :slight_smile:
Sorry SGS didn’t know that. :sweat: Thanks for pointing it out.
That’s true.
This one too,
another user steel it :wink: to use it as his avatar.
Have a look :wink:
Great work @NaN :slight_smile:
Now I must work on a better icon (SVG) :smiley:
Also remove the line under the icon.
That is good.
Done :smiley:
Better.
Didn’t I see @sammiev just the other day? Somewhere?
They say the knees are the second thing old age robs you of.
First the hair, then the knees.
I forgot to add…I literally forgot, which proves the point. I guess.
I can’t remember the first.
That should make better sense.
What that has to do with icons & waybar eludes me. I guess that’s.just.one.more.thing. :reminder_ribbon:
To be fair your work is very cool. I can understand the itch to surround yourself with beautiful and cool stuff. :grin:
Uff that just sounds painful. :Shiver:
Woah! is stealing allowed?
I’m not allowing anyone to steal my pfp :no_entry_sign: (with it being specially made by you :smiling_face_with_three_hearts:)
Thank you NaN ! Always wanted to have a dragon in that corner
waybar_dragon
That’s not firedragon in KDE dr460nized, isn’t it? :smiley:
