How do I activate wayland on Garuda Linux?
I have hybrid laptop but never usually activate nvidia drivers so i don’t care if nvidia will work or not on wayland
@nico
Edit
/etc/gdm/custom.conf
Then
Change
WaylandEnable=false
To
#WaylandEnable=false
I mark it to solved
I've updated the custom.conf
# GDM configuration storage
[daemon]
AutomaticLoginEnable=True
# Uncomment the line below to force the login screen to use Xorg
DefaultSession=gnome-xorg.desktop
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
#Enable=true
But echo $XDG_SESSION_TYPE
still shows "x11." Is that correct?
Might be that?
Agreed. Just not sure what that should be for KDE and Wayland. I've never had Gnome installed.
Then I wonder why you chose this thread to ask about this as it clearly says GNOME
my apologies. i just did a search for Garuda and Wayland and it took me to this thread. I'll post elsewhere.
Try this. I personally have it in my .zshrc
and it works like a charm but the article mentions bash_profile
